Question about Brother MFC-8460N All-In-One Printer
I have a brother MFC-8460N and I keep getting ink marks on my drum. I clean it good and try to print again and it goes back on the drum. It makes big lines on the page. What should I do?
  • hecd24 Feb 18, 2009
    All modes do this. I just got a new toner and it does the same thing so I have ruled that out. The problem seems to be the roller that is in the actual toner holder. I clean it and then ink gets back on the drum I just cleaned. It just starts caking up in certain areas. That is where the lines come from. Just don't know what to do from here. I ruled out the toner because I just bought a new one. I checked everything else inside there and everything is fine. I know it has to do with the toner and the drum when they make contact to make a print. It is like it is to hot like it is melting it on the drum. What else could it be?
  • 215 Answers
What you are seeing is indicative of the drum charge corona being dirty. locate the blueish colored plastic tab on the drum unit and slide back and forth several times making sure you put back on the same side it was before you started. that will take care of it 90% of the time. if it doesn't, write back and we'll go further.
hth,
razors
Posted on Feb 27, 2009
Check the drum cartridge for marks on it, if that dose not fix
is the toner cartridge genuine some remanufacted one are dodgie
the drum cartridge sould last approx 30,000 print outs
the worst case could be your fuser unit. only other option is to clean inside the machine. ps do not touch drum unit, drum
as it will duplicate finger prints and scratches.
Posted on Feb 18, 2009
  • jmtwylie Feb 18, 2009
    i have had a second thought check all contacts inside of machine. isolate this fault
    do you have these line on all function. eg print mode, copy mode, fax mode.
    allways check the platen glass & the thin scan glass for marks on it, again try these options.
    let me know how you go..
I keep getting the message, "Toner error, replace drum unit". I have a MFC Brother 8460N. Jane
Have you replaced the Drum unit? Drum unit on Brothers can be reset if copy is good and you do not want to replace. If copy bad replace Drum. Rebuilt drums work as good as original at half price.
Mar 23, 2017 | Brother MFC-8460N All-In-One Printer
I have a Brother MFC 8460N that prints three black dots down the right side of each page when going through the printer. I have tried cleaning and it does not work. The black dots show up on copies as...
Measure the distance between the dots and that will give you the answer to which roller is causing the problem I believe the Drum is the only roller large enough to just cause three dots.
Aug 28, 2013 | Brother MFC-8460N All-In-One Printer
Clean print heads brother MFC J425W
This is what I figured out to get the printing back to normal.
Open up the printer so you are looking at the place where the print heads go back and forth, you will also see the paper feeder. In the back left corner is where the ink is dispensed. There was build up on mine. As usual grab a 10 or so q-tips and some rubbing alcohol and clean the build up of goopy ink.
You won't ever get it completely clean because more ink will keep dispensing. Close it up and run a test print again.
Jan 25, 2013 | Brother MFC-J425W Inkjet Multifunction...
What does it mean when you get drum error on a brother 8460N
The drum error either tells you to run the blue plastic tab back and forth several times to clean the corona, or the max print count is reached and you need a new drum. If quality looks good you can open the front door and press options or menu and you can reset the drum count.
Nov 05, 2009 | Brother MFC-8460N All-In-One Printer
MFC-8460N Drum Changed - cannot clear DRUM NEAR END message
This sometimes happen when you dont use genuine cartridges/drums, you can leave it flash just let everyone know to watch for changes in print quality since you will no longer have a warning for this drum. when its near its end.
Feb 24, 2009 | Brother MFC-8460N All-In-One Printer
My Brpther MFC-8460n Printing is very garbled print
Try moving the blue slider on the cartridge end to end 10 times.
I no good, you need a new toner cartridge/drum.
Jan 16, 2009 | Brother MFC-8460N All-In-One Printer
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Print problems with brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Brother MFC-8460N All-In-One Printer Logo
347 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
