Question about Motorola Mobility RAZR V3xx Cellular Phone
I bought a memory card for my v3xx razor phone with At&t i do not know how to get it to work. I do not have a camera to put it in to take a picture. How can I do it with my phone only?
    President:
  • 949 Answers
You must not have a v3xx, because the v3xx uses a mirco sd card
and the slot is next to the sim card slot.Also the v3xx has a camera,
and there is no option to get this model without a camera.
The v3 does not have a memory card, but has camera also.
If you do find the slot,if you have a v3xx,then go to your menu and then open connection, then open,phone status, then scroll down to
storage devices,open it, should be left top button, pick options,now you should see,details,rename,format, format the card, this should allow the phone to see the card. There are some brands that just don't work with a phone. I have always used kingston. I have around 12 different type's and they have always been a great card.
Posted on Mar 24, 2009
  • odiebugs
    odiebugs Mar 24, 2009
    Localwonder, if you go to motorola.com and enter the V3xx into there search,you can look at the manual and see that the phone uses a card.
  • 6,784 Answers
Unfortunately, this model dosen't support SD micro cards (memcards). You can use this via bluetooth if your PC is compatible and, it has a bus slot to support micrSD mem.
Posted on Feb 17, 2009
My motorola razr v3xx wont reconize memory card when i put it in. i need to get those pics off of the phone
Perhaps it's not the type of memory card your phone can assess through. If it's urgent then connect your pictures to the com first and transfer first?
May 04, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
I dont know how to send files to my motorola razor
Bluetooth is the only way I know to get ringtones onto your V3 other than downloading the ringtones or ordering a program called motorola phone tools. Your V3 isn't capable of whole songs. I have a phone that is a V3xx and it has a memory card that is recognized by windows as an external drive.
Mar 24, 2009 | Motorola Mobility RAZR V3
I just got a memory card I can't get it to work.
She/He as a i presume have the V3xx.
(this is about the same for all Razrs that take memory cards/Trans flash)
-Menu
-Settings/tools
-System
-Device Info
then to
-Storage Devices
and if it shows up than obviouslt your cards working and the phone knows its there.
if not, a lil trick i found.
Put the transflash card (your lil memory card) into the SD adapter and put it into a camera and take a picture. check and see if the picture is saved on the card. If it is than pop it in your phone and see if you can find that picture. if you dont see it on your camera, its the card.
also if it is listed in your Storage devices.
but for some reason when you take a picture it doesnt save to the memory card?
go into your camera settings and change your storage device to the memory card.
at default it sets your phone as the primary storage, not you memory card.
I hope this helped.
Feb 17, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Can you provide free unlocking codes for Motorola Razr V3xx
Hopefully this will work for you. Go to your cell phone provider and ask them for a 3G Sim card. To my knowledge all V3XX are 3G. I discovered that my service provider had 3G SIM cards after I purchased my husband a v3xx and he had problems with his service. I was told by the service technician when I called for help to try the 3G and it made the difference for my husbands v3XX. I am not certain this will fix your issues but it is always best to use an item t hat has been made special for that phone type... Meaning 3G.... I hope it works. I don't know if it will cost you anything or not. In my state they do not charge for SIM cards. But I have heard that some other states charge around $20 for a SIM card.
Jan 13, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Razr v3xx mp3 player
all right so you purchased the memory sticks and the usb cord so your good to go first thing is the small memory stick needs to go in the phone so to do this remove the back cover of the razor and there should be underneath the battery left to the sim card a slot insert the memory stick in the slot(follow the arrows) attach the cover. next take the larger of the memory stick or the adapter and if computer compatible insert into computer (optional) next take the usb adapter cord insert the large usb side into the computer the other side in to the charge port on the razor. a window should come right up asking ou what to do click view folders now when next window comes up select the folder and drag music into appropriate folder. any further questions or more indepth instructions nmartell@comcast.net only for actual help no **** please
Apr 29, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Razor v3xx subsidy code
cracked front plate on a razr v3xx can it be repaired and how
Feb 25, 2008 | Motorola Mobility RAZR V3
Software for my pictures
Better Call a repair or ...Do you have a warranty card? If yes,Thank god!!! If No,Too Bad,So Sad,Gonna Make Your Momma Mad! (Mad As In Angry)
So Long Chickenmomma! HaHaHaHaHaHaHaHaHaHaHaHaHa
Feb 13, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Memory card
I HAVE A 1200 MODEL MICRO 512 MB CARD AND mp3 SONGS LOADED IN IT.I WANTED TO DELETE SOME OF THE SONGS FROM THE MICRO SDCARD ,,BUT I COULD NOT DELETE THE SONGS .PLEASE GIVE THE PROCEDURE TO DELETE THE UNWANTED SONGS..
FROM, N.DAKSHINAMURTHY.
COIMBATORE /INDIA
Feb 09, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
V3xx camera
Have you tried turning the phone off, removing the battery for several minutes and putting the battery back in and restarting the phone?
Jan 30, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Put names and num. on sim card
go to your address book. left click on options. scroll down to select multiple to.... the transfer numbers to sim from phone.
Nov 21, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola Mobility RAZR V3xx Cellular Phone Logo
286 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
