Question about Everex StepNote NC1500 Notebook
I dont have driver for Pci bus 1 n realtek pci ethernet adapter?can u send me driver 4 dat?Pls rply asap!
  • Jatin Wig May 11, 2010
    what is the model number of that adapter.?
Ethernet controller for msi k9n6sgm-v
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
hope this helps
May 25, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Benicia GL8e (Asus IPIBL-LA) motherboard in HP pavilion - need a network driver
hope this helps
May 09, 2011 | Computers & Internet
Update Drivers pour REALTEK8139/810X Family fast Ethernet NIC sur "XP"
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Apr 30, 2011 | Televison & Video
KV8-X motherboard. I have a network card installed, but I keep getting new hardware found for ethernet. I try to disable the ethernet card via system. I can't connect to internet.
hope this helps
Apr 26, 2011 | AMD ASUS K8V-X (MBASUSK8VX) Motherboard
Wndows vista
All the drivers for that motherboard can be download from the official site at http://www.asrock.com/mb/download.asp?Model=Wolfdale1333-GLAN/M&s=775
Good luck
Jun 20, 2009 | Computers & Internet
Drivers needed
1&lk=1&la=en&nh=10&rf=0&qs=&hpvc=sitewide&uf=1&st=1&qt=HP+HP+Pavilion+dv+9858&submitsearch.x=7&submitsearch.y=8
Apr 11, 2009 | HP Pavilion dv9700t Notebook PC
CANNOT FIND INSTALLER FOR REALTEK RTL8168C(P)8111C(P)PCI-E GIGABIT ETHERNET NIC.can u give any website 4 free download this ethernet nic
http://www.realtek.cz/realtek-driver.php?realtek=network
Select the driver you need from the list.
Jan 24, 2009 | Computers & Internet
Wireless card not functioning/disabled after loading XP in a Compaq Presario C700T CTO Notebook PC
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033108&lc=en&cc=us&lang=en&os=2093&product=3632144&dlc=en
or
http://tinyurl.com/35dt4h
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
Feb 26, 2008 | Compaq Presario 700 470024-192 Notebook
Everex StepNote NC1500 Notebook Logo
191 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
