Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Orange flakes like a thin scrapes of wax show up in ice and water
Refrig not used for a year. Now 2 new filters tried. Thin flakes of orange "stuff" in water and ice. House water is clear. Problem seems to be after the filter. What/where could this be happening?
  • dcw29palms Feb 20, 2009
    Haven't had a chance to try it yet, but it makes perfect sense!
    President:
  • 2,976 Answers
There was water in the lines that evaporated and this is the residue that was left. If you gan get to the inlet, put some full strength white vinegar in it and let it soak for 10 - 30 minutes. This will soften and break loose the remaining deposits. Connect the water supply and flush well.
Posted on Feb 17, 2009
Paint flaked off. How to repaint?
Scrape off any loose paint. Sand it down, removing any rust. Use an enamel spray paint primer first. Then finish with a good quality exterior spray paint like rustoleum. Put on a few thin layers of paint allowing it to dry between coats.
Feb 21, 2016 | Garden
My ice cubes are not solid and very thin I have had a lot of repairs for m;y ice makers. One time a tech told me the water leading to ice maker is no good. Is there anything we can do to solve thin ice...
HI.CHECK FOR WATER SUPPLY VALVE WATER PRESSURE COMMING INTO THE UNIT,AND REFRIG SELENOID VALVE,IF THE PRESSURE IS OK ,REPLACED THE ICE MAKER,,ALSO CHECK FILTER AND WATER TUBE FOR WATER LEAKS..
Jul 05, 2011 | Sub-Zero 650 / O Bottom Freezer...
1993 buick lasabre
Does it turn over?
Could be dead battery
ignition fuse
Jan 29, 2010 | 1993 Buick LeSabre
Our Whirlpool Refrig GD25DFXFW02 is working fine our problem is the ice maker , the cubes contain white flakes, is there a coating on the ice maker that could be chipping off> We have changed the filter...
The inside coating has come off the inside of the ice maker . The white " flakes " is calcium deposits , sticking to the exposed cast metal , inside the ice maker , and sticking to the cubes , after water freezing in the mold . You need to replace the ice maker .
Nov 02, 2009 | Whirlpool ED2FHEXN Side by Side...
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Sep 23, 2008 | Kenwood KDC-3024 CD Player
Cleaning the bottom of my rowenta irom.
Wad up a large piece of wax paper, turn off your steam and "iron" the ball of wax paper. The gunk comes right off the iron and sticks to the wax paper.
Jul 13, 2008 | Rowenta Perfect Iron
Black flakes, like mold in water dispenser
check your water reservoir lower part of refrig. section ( take out crispers)
Dec 14, 2007 | Frigidaire FRS23R4A Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
135 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
