Question about Ricoh Aficio SP-C210SF Printer
Line when coping from document feeder
I get line on copied documents that are copied from the document feeder. There is no line when printing or when scannining from the glass. This line runs full length of the paper slightly left of center. Have tried cleaning the wheels that I can see from under the cover but did not help.Thanks for any ideas
  • raymondh801 Feb 18, 2009
    Thank You for your quick reply. When I open the document feeder cover I do not see any glass. It looks like a mecanism that will need to be taken apart as there are a number of screws and clicps that look like they hold things together. Not sure what I will all run into if I do that. Do you know of a break down sheet on this unit?
    Thank You
  • raymondh801 Feb 20, 2009
    I feel dump having to have this so clearly defined before I got it fixed. The fix is exactly as easy as is stated in the first comment. I was just blind to there being 2 different scanning glasses there.
    THANK YOU for the excelent help
    Ray
The first solution is correct. There are two pieces of glass (the second one is one inch wide at the left side of the printer next to the big piece of glass). I missed it the first time like the other guy. This is my second Brother scanner, and both did this. Thank goodness I found this solution so I can salvage this printer. Thank you so much!
Posted on Jun 15, 2012
  • 15 Answers
If there is a line only when copying from the feeder then there is most likely some crud on the **** glass.
Posted on Mar 01, 2009
If you lift the document feeder, you will see a narrow piece of glass on the left side. Originals are scanned across this when the feeder is used, so a small speck of dirt becomes a line when copying. clean the glass, and it should be good to go.
Posted on Feb 17, 2009
  • Anonymous Feb 19, 2009
    You don't need to take it apart. If you don't have a user manual, you can get it here:
    http://support.ricoh.com/bb_v1oi/pub_e/o...
    Instructions for what I described are on page C-22
  • Anonymous Feb 20, 2009
    My pleasure Ray.
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
I have a dark line through the middle of the page on everything I print. How do you clean the rollers or what do I need to do to correct this? I bought this used and dont have any manuals. I printed...
First step. Using the glass, no document feeder, make a copy. Does it have the line going through it. If it does you need to replace the toner cartridge. If it doesn't then you have a small piece of dirt on the glass that document feeder uses to scan. It is usually a seperated piece of glass next to the large glass used for manual coping. Just clean that and you should be fine.
Feb 14, 2011 | Canon ImageCLASS MF4370dn Laser All-in-One...
Ricoh MP 2500 copied documents have a line across top of page when fed into document feeder when document is scanned the line appears on the scanned version as well. line does not appear on...
Clean the scanner strip glass. This is the thinner strip of glass that runs from front to back right next to the large glass. This glass is only used when scanning/copying using the document feeder. The line you are seeing is because something has become stuck to the glass so when the documents are fed over the strip of glass, the scanner reads the stationary spot of debris as a solid line. Clean the glass very well using a cloth and some glass cleaner. I have seen something get under the glass as well but this is very rare. Rest assured tho that the line is being caused by something on this strip of glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 21, 2010 | Office Equipment & Supplies
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Black lines when you fax and copy
Open up the document feeder and clean the small scanner glass.
Feb 18, 2009 | HP Officejet 6310 All-In-One InkJet...
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Line on fax when sending or coping.
Open the document feeder (the keypad assy) and look for wite-out on the small scanner glass.
Aug 03, 2008 | Brother IntelliFax-4100e Fax
HP color laserjet 2840
If you are copying trough a sheet feeder or document feeder, you will need to clean a thin glass **** from where the documnet is scanned for copying.
Jul 10, 2008 | Office Equipment & Supplies
Copier leaves an ink line down the front of the document when fed through the unit.
Hi there if the line appears when you use the document feeder then there is usually either Correction fluid or pen ink on the small piece of glass to the left of the main glass when you open the lid you can easily clean this by wiping the glass with windowlene or some sort of glass cleaner and this will get rid of your problem.
If the line appears when coping from the glass then the printout from the computer will be the same and that usually means that the print heads need cleaning. Take them out and using a soft cloth wipe the print heads clean from any dried toner.
Hope this help you
Thanks J
Jan 13, 2008 | HP 5510 4-in-one Printer
Ricoh Aficio SP-C210SF Printer Logo
243 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
