Question about Noritz 7.1 Gpm Natural Ng Gas Tankless Hot Water Heater
Noritz tankless water heater/dishwasher not hot enough to clean
We have a Noritz tankless water heater that we installed 2 years ago. Our showers and clothes washer seem to function fine. It is our dishwasher that seems to take forever to clean a load of dishes. We let the sink faucet run until the water is hot then turn on the dishwasher while it is running...to insure there is hot water to start the load. The load still takes forever to wash and I'm not sure how sanitized the load actually is at the end.
Has anyone else had a problem between their tankless water heater and their dishwasher?
    Problem Solver:
  • 6 Answers
You are doing everything you can. Your dishwasher probably isn't drawing enough hot water to activate the unit so opening the faucet and flowing more water will activate the unit. Just try to adjust the flow from the faucet to a point it, plus the draw from the dishwasher, will activate the unit. This will come with trial and error as I am sure you have already experienced. Also, open the dishwasher when it does get filled and check the water temperature. You might have the unit set at a low discharge temperature. Do you have a touchpad to control the water temperature adjustment?
Posted on Jun 10, 2009
  • hooper200 Apr 09, 2011
    I have a noritz tankless hot water heater and am convinced the dishwasher is not being supplied sufficient hot water. I have noticed at the kitchen sink, when the water is not on full blast the hot water is luke warm. The noritz is still running and says 120 degrees, but the water is just luke warm(if the flow rate is not full blast). My dishes are never clean!!! Is there a solution to this dishwasher delima???
  • Tim Dice
    Tim Dice Nov 02, 2011
    hi, we just installed a new tankless reheam and there is no hot water in our dishwasher when filling. I check it several times and it was cold water. I turned on the kitchen faucet and I had hot water. I am not sure what to do and mwould like to have a answer if anyone can help me. Our email address is ttdick@usa.net. Any advise would be great. Thanks for your help.. Tim
We want to adjust our Noritz tankless water heater to come on sooner and heat water for the washer and dishwasher which are far from the kitchen and laundry. How can we get more hot water to them?
You can't. They are an on-demand system. You turn the tap on, the burners light up and eventually the water is hot enough. It is one of the drawbacks of a tankless system. In normal circumstances you can adjust the water to be hotter by reducing the flow, but with dishwashers and laundry washers, you have no control, the water inlet solenoid opens fully. Both your appliances should have heating elements in them to compensate.
Nov 27, 2017 | Noritz Water Heaters
Noritz NR98-DVC tankless water heater won't give hot water thru a single valve fixture. Gives us all the hot water we want on a double handled fixture. Any suggestions on what to do?
Replace single-handled faucet cartridge, and see if hot flows to that faucet again.
http://waterheatertimer.org/Crossover.html
Exposing tankless to hard water causes reduced efficiency within a few months, and can cause Total failure of parts within two years.
Do not expose tankless to more than 11 grains hard water.
Here is research pdf conducted by water softener industry comparing tankless andf tank-type:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
To solve problem long-long term, install tank-type gas water heater from local box store for $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Oct 12, 2012 | Noritz NR98-DVC-NG 100W Freeze Tankless...
It turns on ,starts to get warm.Then turns off
Sounds like you have a problem with water flow. Since your ground water is warmer in the summer, you mix less hot and more cold in order to get the same warm temperature. If your hot water flow gets low enough, your tankless will start to "short cycle" in order to prevent scalding. Use one of these three methods to increase your water flow at the shower:
1) Clean your shower head and descale
2) Widen the hole in the showerhead's flow restrictor
3) Remove your flow restrictor entirely
Aug 02, 2010 | Noritz 6.3 Gallon Residential Tankless...
Difficult to turn the water heater
step one... remove from wall
step two... throw in dumpster
step three... purchase and install a quality tankless water heater.
Rinnai, takagi, Noritz are the only brands I install now. Aquastar (Bosch) always had problems, then purchased by Bosch but never fixed the problems, just put their name on it and sold them at Lowes or home depot.
Garbage!
Jul 31, 2010 | Bosch & Tankless LP Hot Water Heater
How do you fix hot water shuts off during shower with Model N-069M-OD installed December 2006?
Try flowing more hot water with your shower. During the summer you end up mixing alot of cold water and very little hot water (because your cold ground water isn't so cold in the summer). When you get close the minimum flow rate of the appliance, it will start to short cycle (fire on and off). Here's some recommended things you can do:
1) Clean the shower head - remove scale deposits and or clogging
2) Widden flow restrictor - most shower heads have a flow restrictor on the back of the showerhead; It consists of a rubber washer with a hole in the center. You can widen the hole using a drill bit.
3) remove the flow restrictor - this should be a last resort
Jul 22, 2010 | Noritz 6.3 Gallon Residential Tankless...
Hello, I purchased a Bosch model # GWH G35 ES N about 4 years ago and have continuous problems with the sensors. I've replaced the hot side outlet sensor #0711 at least 4 times and the cold side # 0616...
the main problem is...
you purchased a "Bosch" Aquastar.... complete garbage
if you want quality tankless..
Takagi, Rinnai, or Noritz. these are the only tankless I install or work on, very few if any problems.
just look on the board here, most of the problems listed are with the Bosch
Jul 10, 2010 | Bosch Water Heaters
Water becomes ice cold in the middle of a shower
Jan 24, 2010 | Noritz NORTIZ Outdoor Propane Tankless...
First it takes over two minutes to get hot water 30 feet away. Then when it's finally hot and adjusted to a comfortable setting in the shower, it only lasts maybe 3 minutes. And in the same room, the...
If the unit is functioning properly, then you need to contact your utility company to see about upgrading the size of the gas line and meter to your house, and possibly the lines IN th house. It may be cheaper to go back to a tank type water heater despite the potential energy savings with a tankless.
Oct 09, 2009 | Noritz 6.9 Gallon Residential Tankless...
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Noritz 7.1 Gpm Natural Ng Gas Tankless Hot Water Heater Logo
942 people viewed this question
Top Noritz Water Heaters Experts
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
