Question about GE 26998GE1 Cordless Phone
HOw do I get the phone to ring more than 3 times before the answer machine picks up?
    Genius:
  • 1,605 Answers
Go to the following link to get the user manaul and program the phone.
http://www.amazon.com/26998ge1-Analog-Cordless-Digital-Answering/dp/
Posted on May 20, 2009
Extend number of rings before answering machine
The 6041 isn't an answering machine. It will ring until you pick up, an answering machine or voicemail system picks up, or the caller hangs up.
Please refer to the documentation for whatever answering machine or voicemail system you have on your phone line. If you require further assistance, please add a comment to this question and specify the answering machine or voicemail system.
Dec 26, 2013 | Vtech Cordless 6041 Phone
How to adjust how many rings on answer machine
Since you declined to give the model of your VTech system, please enter it into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Nov 13, 2013 | Vtech Lands Phones
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
Our digital answering feature now picks up after 2 rings it has always rang 4 times. Is there a way to adjust back to 4 rings?
on answering machine you need to do the following:
1. Press menu 3 times
2. Press repeat/rew or skip/ff until 4 is displayed.
3. Press set/ringer to store it for 4 rings.
Your done! set to 4 rings!!!!!
May 15, 2010 | Uniden Cordless Phone exai398i
Can you please tell me how to shorten the amount
Got it, and you can set it for 2, 4, or 6 rings on incoming calls.
1. Press MENU/CLOCK on the base to enter setup.
2. Press MENU/CLOCK repeatedly to select RING TIME.
3. Press VOL:/SELECT to set the number or rings at 2, 4, or 6.
4. Press SET to save the setting.
You can download and print the operating manual for youir phone system at
http://www.uniden.com/pdf/DXAI8580-2om.pdf
Dec 11, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Ow doyou set it to ring four times before the
Press menu 3 times. Then press either repeat/rew or skip/ff to get to 4. Press set/ringer to store your changes.
That is all it takes to get your 4 ring then answer maching picks up.
Nov 20, 2009 | Uniden Cordless Phone exai398i
Set number of rings before answer machine pick up
From the main menu select the Voice Mail option in Voice mail select Ring Delay in Ring Delay you can choose the delay time before Answering Machine pick up the phone from 0 to 30 secend.Reza from Iran
Oct 01, 2008 | Siemens Gigaset S455 Cordless Phone
GE 26998GE1 Cordless Phone Logo
132 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
