Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Motor clicks but will not open door
I replaced the gears and the motor will click and hum a little. If I use a plier to turn the shaft coming out of the motor the opener will work a couple of times and then stop working. The yellow light on the back flashes constantly. Any suggestions or advice
  • huntndogz Feb 17, 2009
    Any idea what is causing the motor to overheat? There was no problem until the gears were changed.
    Problem Solver:
  • 6 Answers
Does it simply click then hum? or does it sound like something's moving inside? if you can hear movement inside I'd guess stripped gears. if it just hums I'd have to agree that the chain is bound somewhere. Either way it doesn't sound like it's the electric eyes to me. You should be able to bypass them if you still want to but you have to know if your model uses NO or NC contacts first.
Posted on Feb 18, 2009
  • mike Feb 18, 2009
    oops, wrong thread... I meant that answer for John_Farrell.
    I would check the gear assembly again.. it sounds like something's a little too tight in there. Possibly a gear just not in all the way and the end is rubbing. Good luck
    Problem Solver:
  • 6 Answers
Motor is over heated shut down unplug 30 min
Posted on Feb 17, 2009
As you push remote door travels a shot distance stops,push button and travels short distance again and again. What is wrong?
Most common failure is internal plastic gear. If we assume that this is the failure i would suggest disconnect the travel engage latch to the non engaged position. Cycle the door and observe if there comes a time that the motor is humming and the chain or latch is not moving. Other than reversing for just a brief moment at the end of travel at no time should the motor hum as turning and the latch feature not move.
What I suspect is happening in the down direction door wants to close and as the gear rotates the gear slips . This repair is not so difficult for the DIY with some mechanic skills and tools. Lots of u-tube showing you how, Parts are available. Confirm the right part for your specific model. Purchase the gear and shaft as an assembly if you not sure about the difficulty. Part prices are all over the map. Shop around. You can buy just the gear a little more difficult to replace.
His 15 minute estimate may be a little optimistic.
Craftsman LiftMaster Garage Door Opener Won Open or Close Fix the Stripped...
Jan 10, 2016 | Building Materials
Electric motor hums but does not open or close garage door
If it just hums and not actually run. Then the trolley is jammed against one of the stop bolts.
Mar 26, 2014 | Building Materials
I have a Craftsman 1/2 hp, mod # 139.53603. When I press the remote or the panel button there is a humming sound from the motor. I opened the panel on the back and did not see anything out of line, etc. ...
Is the trolley jammed against the bolt just in front of the motor? If so, loosen the chain until the tension is off the trolley and then run the motor until the door is closed. Now locate the up limit on the side of the motor unit and turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have the Craftsman 1/2 hp Garage Door Opener model 139.53674SRT1. It was working except for needing the main gear changed. Changed the gear and now the opener only clicks and does not actaully open or...
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Jan 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster GDO makes a clicking sound and won't open
See if the trolley is jammed against the bolt just in front of the motor unit. If so remove the bolt and then run the opener until the door is closed. While the door is closed locate the 'up limit' control which is on the side of the motor unit. Turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Remember to replace the bolt.
Jan 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Opener will hum but not engage the drive train.
If the humming you hear is the motor running you need to remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. If it is the motor humming but not turning you have a bad start capacitor which is held by a bracket and is next to the motor.
Sep 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
My door went down so far it flexed the bar and broke from the wal
You seem to have more than one issue.  Why did the bar flex in the first place?  If you have a Craftsman or Liftmaster operator, unplug the operator and remove the cover.  On the motor shaft, carefully, use a pair of pliers or vicegrips to turn the motor shaft in a direction to move the carriage away from the bolt.  This may not be the only problem, the gear assembly part # 41C4220A may need to be replaced.  I'm still wondering why the bar flexed in the first place?
Dec 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP - humming, but does not open.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
Oct 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Clothes dryer ran ok an hour ago - not now
you may have a bushing problem on the drive motor due to dirt or flint. you can check that by removing the belt and try rotating the motor manually. see if it is easy to turn or not.check also the bushing if you can move the shaft sideways..if it has a slack then its a bushing problem. replace the drive motor.
Feb 03, 2008 | Dryers
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
419 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
