Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Electrical Problem with Sears opener
When I tried to operate the opener, there was an electrical flash and some smoke. Now the unit won't operate at all. The wall button isn't lit. Visual inspection of the logic board, motor, terminal block, and capacitor showed nothing. How can I determine which component is bad?
  • 6,784 Answers
Hi there, i would suggest a break point test with a voltage test needle. Im sure that this electrical surge has torched your power supply board. this is the reason for the non operative state.
Posted on Feb 17, 2009
I have an oil fired aga the oil will not come throw to the burner
see the following steps:
f the burner doesn't run, set the thermostat a few degrees higher than normal to see if it comes on. If it still doesn't come on, check switches, and breakers and fuses (see the Electrical Service Panel Fix-It Guide). If the unit has a reset button, press it. Also oil the motor at any oil ports (see below). If the unit doesn't want to start and run, first check the c to make sure that the ignition is getting power. If there is power, check the built-in safety controls (see below) that may turn the system off if they perceive problems.
If the burner cycles too often, replace the filter (see below). Also, oil and adjust the blower (see the Forced-Air Distribution Fix-It Guide).
If the burner runs but won't fire, make sure the oil valves are open and that there's oil in the tank. Check the tank level with a clean stick.
If the burner smokes or squeals, shut off the unit, let it cool, and fill the oil cups. Recheck them after the motor has run for an hour.
If the chimney smokes even after the flue has warmed up, the unit is wasting fuel; call for professional repair.
Safety Controls
Oil furnaces and other heat systems include safety devices that monitor operation and turn off the unit if something goes wrong. In some cases, the safety device can be the problem.
If you encounter an operating problem with an oil furnace, first reset the safety and try again.
If the burner kicks off again, shut off all power at the electrical service panel ; the burner motor and ignition may be protected by separate fuses or breakers.
If the sensor has a photocell, wipe it with a clean rag or tissue and see if the furnace starts.
If the safety is a stack switch mounted on the flue, remove the screw holding the unit to the stack, slide it out, and wipe off the sensor.
If the furnace won't start after three tries, seek professional assistance. Unburned oil can accumulate in the combustion chamber and "flash back."
Jul 31, 2012 | Heating & Cooling
The wired keypad (Chamberlain) of my garage door is not working. The red light on the keypad keeps blinking. Can someone tell me how to fix that? FYI, the garage opener, the remote, and the wall unit all...
You can try programming the keypad using the procedure below.
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Mar 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
One beep constantly on smoke and CO unit. says battery low but the system is wired into house panel. Help!
Most new smoke detectors work off of two power sources, electric and battery backup. The battery is used to power the detector if primary electrical AC power is lost. It would be a good idea to replace all detector batteries every two years or so. You'll access the battery by opening the unit, find out the type used and then purchase a replacement at your local store. Hope this helps.
Apr 15, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Chamberlain 1/2hp Operator won't work after electrical storm
Sounds like the circuit board got zapped. You could price a new board or take it apart and check the components if you know how, but normal mortals would just buy a new unit.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have 2 sears door opener the remote not workinng we re set the coadswill not open door
FIRST CHECK TO SEE IF THE LOCK/VACATION BUTTON ON THE WALL CONTROL HAS BEEN ACTIVATED. THE LED ON THE WALL CONTROL WILL BE FLASHING. - SIMPLE SOLUTION PUSH THE LOCK BUTTON AND HOLD FOR 2 SECONDS TO TURN OFF LOCK FUNCTION.
SECOND TRY TO REPROGRAM THE REMOTES TO THE UNIT - THEY WILL SOMETIMES LOSE MEMORY IN AN ELECTRICAL STORM.
IF REPROGRAMMING DOESN’T HELP TRY REPLACING THE BATTERIES IN THE REMOTES AND THEN REPROGRAM.
HOPE THIS HELPS
Mar 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens and then closes wright away
I figured out that when I replaced the gears, I damaged the RPM sensor. It was easy to swap out the old for the new and now it works fine.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Electrical problem with logic board or terminal block
do you see burn mark on board? Is so and unit is older than 15 years, buy new one.
Feb 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
