Question about Sony Cyber-Shot DSC-T1 Digital Camera
When camera ls open it looks like wet paint runnig .
When i open the lense my camera looks like a painting that has had water thrown on it.when i take a picture it comes out the same way
  • 10,594 Answers
This is known problem of CCD Imager and this part needs to be replaced in DSC-T1
Sony will repair your camera free of cost as per announced scheme.
Click Sony CCD Imager Support for details.
Posted on Feb 17, 2009
What is an alcali
Nothing to do with cameras....... Alcali is most probably incorrect spelling for alkali - a mixture of soluble salts found in arid soils and some bodies of water; detrimental to agriculture.
If its related to paints, this is possibly the best advice:
  • Allow fresh masonry surfaces to cure for at least 30 days before painting. If this is not possible, use a high-quality, alkali-resistant primer.
  • Test alkalinity of the surface with phenolphthalein or a pH pencil.
  • Paint with a high-quality water-based paint and avoid colours that are alkali-sensitive.
Jul 13, 2014 | Cameras
I have an old white refrigerator that works fine, just looks awful. What can I do to the face to make it look nice. I have wooden oak kitchen cabinets and a tile floor.
Paint it with white enamel.
Enamel Paint finishes in high gloss if you want that sort of finish.
Always paint in a dust free invironment with plenty of ventiallation.
With the expensive cost of many home appliances, sometimes replacing an old refrigerator is out of the question, especially if it still works well.
This can be a problem if you've recently painted your kitchen or if you're just sick of looking at an old, outdated fridge.
Instead of learning to live with your boring or unattractive refrigerator, you can give it a bright new look with a few coats of paint.
Mix a few tablespoons of vinegar into a bucket of warm soapy water.
Use this mixture to clean the refrigerator.
Scrub away any grease, dirt or other grime with your soapy water and a stiff bristled scrub brush. Wipe the refrigerator dry with a towel when it is clean.
Use painter's tape to cover parts of the refrigerator you do not want to paint such as the handle or the grate at the bottom of the refrigerator.
Apply a coat of appliance paint to your refrigerator with a paint roller to prime the surface.
You can also purchase appliance paint in a spray can and use it to spray paint your refrigerator.
Sand the paint with an extra fine grit sanding sponge when it is completely dry.
Try to make the surface as smooth as possible and then wipe away any dust created with a clean towel.
Paint the refrigerator with an enamel paint tinted to the desired color and a paint roller.
You can use oil-based or latex-based enamel depending on your preferences.
Oil paints usually have a stronger odor than latex paints but they may last longer.
Apply a second coat of paint when the first coat is completely dry.
Sand the final coat of paint when it is dry with a wet extra fine sanding sponge.
Spray the refrigerator with water while you work to keep it damp and keep sanding until the paint is smooth and shiny.
Remove all of the painter's tape from your painted refrigerator.
Sep 08, 2013 | GE Refrigerators
My paint dries to fast, what should I do?
Acrylic paint depends on time, temperature, humidity, paint thickness, air-flow and absorbency to dry.
Reeves Complete Acrylic Painting Set
Oil colour
paint takes long time to dry than other media and it allows to think and it also provides the flexibility for changes.
Williamsburg Handmade Oil Color Paint Alizarin Crimson 37ml Tube
Feb 03, 2013 | Crafts & Hobbies
What is a paint stick?
Paint sticks offer a different way to work with oil paint. Rather than using a brush, you hold the paint stick in your hand to create different lines or textures than you could with a brush.
A trojan horse has infect my camera and changed all my files to shortcuts
Check to see if the actual file content has changed. Try opening one of the files with paint. Open paint and drag one of the files (i'm assuming the files are supposed to be images) onto paint to open it in paint. If the file successfully opens in paint and you see the image, you know that all the virus did was change the extension from the file from .jpg (jpeg image) to .lnk (link or shortcut). If the file does not open successfully where it should, then you know that you have lost your images.
Jul 01, 2011 | Cameras
What is the correct concistancy the paint needs to be mixed at for the dynatec psg 45 electric spray gun
It depends on 3 things.
What you are painting.
Whether you are applying latex, oil-base, or primer.
What size TIP you are using.
We use spray equipment and use size 17 and 19 for latex, and 11 for oil.
Double-check the size that came with your gun and look at tips at Home Depot.
Old tips wallow out and the spray pattern is irregular/uneven and the gun blows out too much paint and our material costs go up.
The manual says "dilute correspondingly"
http://www.airless.com.au/Airless%20Sprayer.pdf
Let's say you are spraying oil-base stain: I would NOT dillute this material.
Oil-base primer: 1 thinner to 4 paint
Latex primer: use a roller and brush so you have a good undercoat for the paint.
Oil-base paint: I would add 1/8 thinner with 1 paint, and be careful of runs
Latex stain: try 1 water to 4 stain
Cheap interior flat latex: 1 water to 4 paint
Latex semi-gloss interior: 1-1/8 to 4 paint and apply very thin coats and let dry between coats.
Cheap exterior flat latex: 1+ to 4 paint, and add more or less water as needed
Good exterior latex paint: use a roller and brush because the purpose of latex exterior pain is to apply heavy protective coat over outdoor materials ... dilluted exterior latex will not give sun and mildew protection.
We use heavy spray equipment and apply exterior latex straight form the can. It's the only way to give lasting job, unless you're doing a temporary playhouse.
The key to successful spraying is to strain your paint to get out the lump and clogs - BEFORE putting paint into the gun.
We always strain the paint unless it's a freshly opened can.
If can was opened yesterday, we strain it.
That because paint gets a dry film that will clog the sprayer.
First you need to mix your material, so you need a couple buckets.
Pour the paint and thinning material in 1 bucket, and then to mix, pour back and forth between two or three buckets. This action will mix the paint thoroughly and save you an hour of rotating a paint stir stick.
Next, you need to strain the paint.
Wash out a 5-gallon bucket.
Buy 5 gallon strainer that fits into bucket.
Pour material into bucket with strainer, lift strainer up and then grab end of strainer and squeeze out all the paint.
Immediately put lid over paint so no drying film will form.
Wash out strainer.
You're ready to put paint in spray gun.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on paint project.
Jan 06, 2011 | Garden
I own this 0525151 and am trying to spray a latex fence stain. worked for a little while, then nothing. I tried thinning the paint with water and a paint thinner product recommended by the Home Depot...
We used paint sprayers every day for years.
Tips come in different sizes. With oil base paints we used the small tip like a 4-11. With latex we used bigger tips, like a 5-17. Really big spray rigs use 5-19. Tip size matters.
Another important thing is to strain the paint. The paint store sells 5-gallon-size strainers. Put the strainer over a 5-gallon bucket. Pour the paint into the bucket. Lift the strainer up, and finally grab it with your hands and squeeze the paint out. Do this in the grass and then wash out the strainer for next time. Put a lid over the paint bucket so the paint stays wet and clean.
We used high pressure sprayers, and then wrapped a filter right over the intake... but the tips would still clog. We had guns with reversible tips ... rotate the tip around, fire the gun, and the clog was gone.
Maybe your tip is getting clogged real fast. When that happens, the gun simply doesn't shoot. The old guns, we had to take them apart every time the tip clogged. I don't know about the tip on your gun.
Your paint sprayer is probably not very high pressure, which means it would clog easily if stuff was in the paint ... and latex is thick and sticky and it gets crusty as it dries.
Suggestion: I would ask Sherwin Williams about the tip. See if they sell parts or tips at the Home Depot or Sherwin Williams.
Also you can clean the gun out with lacquer thinner. See if the lacquer thinner will pass through the gun. I would take it apart and clean everything with a toothbrush, and soak it in lacquer thinner. It might work, but the home-depot-home-owner-spray-equipment is generally not made for more than a few jobs. Especially the wagner-diaphragm-type guns.
Something else you might consider for a cedar-type picket fence. A roller. Sherwin Williams sells thick shaggy roller covers that hold a lot of paint. The little cheap roller covers can't paint a fence or anything else because they're too thin. We almost never sprayed a fence. We'd put masonite along the bottom and then just threw paint up with a roller [slap it on as the customers used to claim] >>> for cedar pickets, thin the paint with water (1 gallon water per 5 of paint) so it flows into the holes and gaps. Roll the fence, and then go back and touch up with a brush or the sprayer. A paint job on a fence always looks better the next day [unlike some things] so sometimes it's best to wait 1 day before doing the brush work.
Oct 13, 2010 | Garden
We have an older knemore Mod 11?713400s/washer and
Clean the old paint surface with TSP cleaner, then sand the surface lightly with ~400 grit wet or dry sandpaper (wet--dip in bucket of warm water often while sanding and sand carefully in any corners). Cut a 1/4-paper-length strip from a full sheet and fold twice into a 1/3-width square. Sand using just your fingers to hold the paper--no sanding block. Wash with clean hot water, and dry with a clean cloth (no paper towels). Mask off the area you don't want painted, then using an epoxy-type paint spray can, spray the area evenly and lightly for the first coat. Follow can directions for the second coat. Remove the masking tape and paper shortly after the second coat--peel the paper and tape AWAY from the new paint at all points and don't let any of it get stuck in the new paint before it drys. If the second coat was applied fully wet overall without running, it should turn out very well. Good luck!
Aug 08, 2009 | Dishwashers
I was painting and i got a run on the fuel door on my 2001 chevy cavalier 2-door, how do i remove the fuel door?
go to paint or auto partstore buy wet sanding paper use water takes alot of elbow work make it perfect smooth sould have that chalk board texture smooth .then buff it very carefule not burn it through the paint just buff slow then polish with wax
Dec 23, 2008 | 1986 Chevrolet Cavalier 2 Door
Sony Cyber-Shot DSC-T1 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
