Question about E-Machines eMachines Desktop PC
No powerup I have a 10 year old e-machine desktop, and when I try to power it up, an orange light keeps flashing and it doesn't power up.
  • 479 Answers
Please first of all you check with the removing the monitor cable and check any message is coming.
2.check with refixing all the cables.
3.check whether fans are moving if not this is the issue with smps or power switch.
4.if fans are moving but no display tap the num lock key if LED on the k/b is blinking then this is a RAM issue otherwise mainboard issue.
Thanks
Posted on Feb 17, 2009
  • Gyanendra Kumar Feb 17, 2009
    For mainboard u will have to check with hardware vender.
  • 139 Answers
Very simple unplg the power cord and the display cable and press the power key on the cpu for 1 min & then plug the power cord and the display cable and again press the power key normally you system will work perfectly.
Its just the extra power on the motherboard which needs to be drained out.
Enjoy ......
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
HP Laserjet 1022 orange light keeps flashing
1. Check any paper jams in side.
2. Check cartridge.
3. Remove back cover, clean paper sensors.
4. Replace Formatter board.
Jan 05, 2013 | HP LaserJet 1022 Printer
Hi, I've had my Acer aspire laptop for a few years now, but I haven't used it for over a year (Because I got a desktop). So when I've come to turn it on today, It won't work. The screen...
Start with pulling the battery and power, then hold the power button in for about 30-40 seconds. Then plug the power back in (still no battery). Try to power up the computer. If it boots, shut it down and put the battery in and try again. If it boots the issue was cleared. If it boots with the power cord but not with the battery added, you have a battery issue.
Hope this helps
Sep 01, 2011 | Computers & Internet
Orange light flashes, but pda will not powerup screen
Hold the reset button button on the back of your device and press the power button
Apr 10, 2010 | Motorola MC50 Pocket PC
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    I been using this for 5 years now and lately... it just wont turn on. i have to wait sumtimes up to 3 hrs. and it makes a noise. then i press the power button and it will work. Also the power button is...
    hello,
    is that light flashing amber/yellow/orange??
    try resetting BIOS and if that doesn help try second tip:
    2: does this PC have USB port with audio ports in the front? if so, open up the side panel of the computer and followr those wire from front USB to motherboard and remove them from MOBO and try powering it up again.....(remember which wire you take off from where, because you will be putting them back if it doesn't solve the problem).
    hope this helps, let me know if there are any questions..
    regards
    Amar Sondhi
    Dec 04, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
    T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
    Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
    Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
    Reconnect the power cord and then check
    Thanks for using fixya
    proton
    Nov 07, 2009 | E-Machines eMachines Desktop PC
    Orange light is flashing
    Unplug the power cord for 10 seconds
    Feb 05, 2009 | HP LaserJet 1020 Printer
    DS Lite does not power up
    If the console has overcharged or has been used for long periods of time or could just be fluke, chances are the fuses are blown on the main motherboard try this link, this guy fixed my ds and i had the exact same problems as you guys have
    Sep 10, 2007 | Nintendo DS Lite Console
    E-Machines eMachines Desktop PC Logo
    94 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
