Question about Home
How do i fit an electric shower to a tiled wall
How do i access the pipes if the wall is tiled
  • craig warmisham Feb 17, 2009
    spot on, thats all i needed to know
  • 10,865 Answers
You may be access the pipes from the other side of the wall containing those pipes. so rather than have to cut into your tiled wall, you will be cutting into whatever is on the other side of that stud wall.
Posted on Feb 17, 2009
  • Joe Hogan Feb 17, 2009
    please rate this as a fixya! after all that is what you indicated that it did for you. thanks.
Seem to have water leaking under shower into storage competition ment, tried caulking only happens when shower is on and someone is in it very frustrating
Very often happens for a number of reasons
Bad caulking around the shower base and the base drops with the weight of the occupant allowing water past the caulking.
Crack and bad seal on a wall tile.
A split in the base itself which opens up with weight and you can't see with the base empty.
A leak in the pipes behind the wall from the mixer unit to the shower head.
Split pipes or fitting to the drain.
Best way is a full tear down, refurbishment and start anew :>)
Jul 10, 2016 | Home
We are staying in a rented home with a spa bath. Attached to the spa bath is a hand held shower. The showerhead rests above the bath but the pipe coils somewhere between the tiles and the bath and can be...
The grout between tiles is just for filling the gaps. The tiles are glued to the wall, usually with "thin-set" mortar. Unless that mortar is in very poor condition it is unlikely that you would be able to remove that single tile without breaking it. The wall behind the tile might be water-resistant drywall (a poor quality situation) or it should be cement-board. I suppose it's possible that there is already a hole in the wall behind the tile, but the hole would be smaller than the tile, and assuming 4 inch (not large) tiles, this is a poor choice to gain access to the pipes. The usual access is through the wall from the other side. During initial construction, a removable access panel is sometimes provided (depending on local building codes and whims of the builder). If there is no access panel, and the other side of the wall is drywall, then cutting a generous hole, and fashioning a plywood panel (with trim around the edge to cover the gap between the drywall and the plywood) is a pretty standard and simple approach (depending on your skills). As an alternative and for more info, here's a link describing how to install a plastic snap-in access panel. Good luck! http://www.diylife.com/2008/06/23/plumbing-access-panel-installation/
Jun 01, 2011 | Home
The device the sprayes water from the shower head has broken. The shower head does not unscrew for the shower arm. The shower arm is attached behind the tiled wall. How do I remove the shower arm and...
The shower arm should be screwed into an elbow inside the wall. Unscrew the shower arm by putting your pipe wrench on the arm and unscrewing in a counter clockwise direction ( lefty loosey, righty tighty ) . Measure the length of the arm going inside the wall and make sure your replacement has enough length to reach. Teflon tape the inside end ( the end going in the wall ) and wrap a rag around the new arm, then screw into the elbow going clock wise , stopping when it starts getting tight and with the bend facing downward. Install shower head.
Nov 20, 2010 | Price Pfister Home
I a leak under my tub, think it's from the shower, it doesn't leak with a full tub of water or ewhen you empty the tub, but when you're in the shower a flow of water comes out under the shower piping side...
Check out the faucet plate mounted on tub side for a good seal. Water can leak down this plate causing it to look like the valve is leaking.
When you are in the shower it splash's water against the valve and water will run down behind it. Check the tub spout and if you have tile check the chaulked joint where tub and wall meet.
Jun 02, 2010 | Plumbing
Overflow outside bathroom dripping how do Ifix it?
Just make sure that the over flow is tight with gasket in place. And all fitting's tight behind wall goin gto tub overflow. If it is check out out next step
1-This is a common issue that comes up. Make sure that the shower valve plate is sealed and tight to tub wall. Reason why I ask that is when you take a shower water will find a way out, down the plate or if tile at the point of where it meet's tub. And will look totally like it's the overflow every time.
May 23, 2010 | Plumb Pak Waste & Overflow Pipe Kit, 1...
Shower stall in master bath of a 15 yr old home. the shower started having water problems after about 1 year, leaking water onto the drywall next to the stall. we have tried everything-recalking, sealing...
Did you use plastic pipe? What about the shower head? Does it have a rubber o-ring in it? Pull the pipe out of the wall at the shower head and peek inside for the o-ring. If it is there, just snug up the pipe, do not over tighten. We were ready with crow bars in hand to destroy a brand new shower we just finished, because we thought we had w broken pipe, Then the owner says he torqued up the shower head as tight as he could and I read where it had to be just finger tight. One more place to check is the faucet itself, take off the trim ring and look in there for drips. It could be filling up the wall cavity and stay wet for days. I would take apart the drywall on the other side before busting up the tile again. Check it out.
Apr 24, 2010 | Kohler Home
Replace old vinyl/plastic type stand up shower - I want to convert over using tile. What do i use as a bottom pan i can tyle over?
You could make a base that would be framed up 2x4's and covered with a waterproofing membrane. lay concrete floor, sloped to drain (2piece) and tile. Or use a fibergass base that fits to studs. And then tile walls.
Sep 21, 2009 | Home
Broken pvc plumbing for bathtub faucet.
if you have tiles in the bathroom wall, the answer is yes!
it is better to go fromthe back, where there is drywall.
since PVC is glue on, you have to cut out the pipe and reconnect.
make sure the bathtub faucet is not broken, and can be reuse.
Nov 11, 2008 | Plumbing
Installation Rules?
There are four golden rules for installing a shower enclosure. The first golden rule is to make sure that the shower tray is level. If it is not, then problems will occur throughout the rest of the installation. Use a good quality spirit level and where possible install a tray that has adjustable legs. There are often problems associated with tiling over upstands as some are thick and difficult to set into the wall. The second golden rule is to install a tray that has a slim tiling up stand which is vertical and an integral part of the tray: This will make the installation easier, quicker and ensure it is totally watertight. Before installing the shower enclosure the third golden rule must be followed. A silicone sealer needs to be applied all the way around the join where the tiles meet the tray: This must be sealed first, to ensure there is no chance of water getting behind the wall channels and then into the walls. This is one of the biggest problems associated with shower installations but is easily solved if the silicon sealer is applied before the enclosure is fitted. The final golden rule is to fit the enclosure to the tiled surface and not on to a plastered wall, tiling up to it afterwards. Having installed the enclosure it is essential to use the same high quality silicone sealer around the outside of the enclosure. Sealing on the inside will cause leaking- not prevent it.
Aug 27, 2008 | Dynasty Hardware Pacific Shower Basket or...
Fitting Electrical Shower -electrician will do final connection at consumer unit
Sorry,
Thought the service was free
Silly me, only found out it wasnot after I had typed the questioin and thought it would then be aired on the forum anyway
Thanks anyway,
Roger
Jul 31, 2008 | Kitchen Appliances - Others
Home Logo
116 people viewed this question
Top Home Experts
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
