Question about IBM ThinkPad X30 2672 Notebook
Stronger wireless card
A friend told me I should upgrade my wireless card for my IBM X30. She said it would make for better signals. Is there a stronger card for my laptop?
  • 27 Answers
There are no stronger or weaker cards (if your's is a 802.11g, which it most probably is unless its VERY old) ...you can try changing the channel on your wireless router...
Posted on Feb 17, 2009
Wifi Signal Problem ???
You have the following options.
1. Move closer to the router
2. Purchase and install a wireless usb adapter that plugs into your usb port from Tiger Direct at: http://www.tigerdirect.com
3. Try using another client to manage your wireless. Usually there are 2 ways to manage your wireless on the laptop. You can use the software that came with your internal wireless card or you can use Windows (zero config) to manage your wireless. Which ever one you are now using, switch to the other. Open the software that controls your wireless and look through the tabs searching for where it will say something like "Let this tool Manage the Wireless" or "Let Windows Zero Config Manage the Wireless". Which ever one it is using switch to the other by checking or unchecking the box. Most times one will produce a better and stronger signal than the other.
Jun 01, 2012 | Dell Inspiron 1420 Laptop
I have a older Toshebia laptop with a wireless lan card that i'd like to update. Can I just download a driver update to apply to the Toshebia rather than buying a new card? Trying to get on-line?
Hi, In this case if you would like to upgrade the performance of your wireless card like to use a wireless connection with better signal strength or signal range then you would need to to purchase a wireless card to upgrade from the existing one however if you are looking to have the performance of the internet connection improved then all that you would need to do is update the wireless card drivers.
Thank you for your time.
Nov 23, 2010 | Computers & Internet
Wireless is interrupted, slow, etc. No problem on IBM. Mac "loads" and "loads" etc., not large files. Just emails, etc.
The Airport icon on the menu bar shows the signal strength -- the more arcs are fully black, the stronger the signal. What signal is showing on your menu bar? Does the problem go away when you move your laptop closer to the wireless signal source? It's possible your Airport card is going bad, or your antenna inside the laptop has become disconnected (the one on my personal machine has disconnected itself twice; the fix was simple and fast but required opening the case).
Jan 21, 2010 | Apple Computers & Internet
How to find more wifi connections with my Linksys WPC54G? I can get connections (sometimes) but would like to find more options (stronger connections).
Upgrade the drivers for the adapter for better connectivity , excellent signal strength and enhance performance.Go the following link:-
http://www.linksysbycisco.com/US/en/support/WPC54G/download
and under select hardware version select the latest one from there , in this case it will be v7.1.
After selecting the v7.1 download the driver associated and enlisted below which will be Ver.4.1.2.95.
Dec 05, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Wireless networking problem
Access points receive the wireless signal and re transmit it again.
Once you enter the web interface of the access point, you would have to connect it to your wireless network. Once that is done, you should be able to connect to the same network , with a stronger signal , from your access point
Thanks Ranjit
Aug 19, 2009 | Cisco Aironet 1100 Wireless Access Point ...
I have a Toshiba L25 laptop and a D-Lin Air DWL-650 wireless card. I'm not getting the best connection with the wireless card while my other computer has a much stronger signal. I'd like a recommendation...
im assuming its a cardbus adapter right? well that model is a wireless b signal, which isnt very strong, so any wireless g model should have a much stronger signal. it doesnt matter which one it is, as long as its wireless g, which most new cards are. hope this helps, goodluck
Jul 09, 2009 | Toshiba Satellite L25-S119 Notebook
Laptop wireless internet connectivity
use the zyxel you have best range and good signal also otherwise you take a acces point and you get it the best of the best link and signal
Jun 10, 2008 | NetGear (IM-WG511T) Wireless Adapter
Ibm think pad t30
To my knowledge, your laptop (IBM ThinkPad X30 2672) does not have any built-in WiFi. It's modes of connection are IrDA, modem, Ethernet, USP, Firewire aside from the regular serial & parallel. This would indicate that if you are wireless you either have a USB dongle or PCMCIA card. Please post back with your WiFi brand/model and your Operating System. Further, please post back likewise your WiFi AP/Router brand/model.
The message "a network cable is unplugged" pertains to the absence of a lan cable connected to your Ethernet port.
Good luck, kind regards and will await your second post.
Nov 16, 2007 | IBM ThinkPad X30 2672 Notebook
IBM ThinkPad X30 2672 Notebook Logo
135 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
