Question about Microsoft Windows Server Standard 2003 for PC
Being able to use disk manager on a second IDE drive
I added a second 40 GB IDE drive to my Windows 2003 server. I can see it in disk manager, but the only option available to me is delete partition. The system does not see it under My Computer. I think it probably has something to do with either the jumper settings on the hard drives, BIOS setup or both.
  • 4 Answers
I think, it isn't a new drive, because a partition ia visible and the file system isn't accessible.
Seems to be a used disk from another computer. May be, its a unix-formatted partition (Ext2/3)
These Partitions are visible, but not accessible.
The disk itself and the cabeling are ok, otherwise you cant see the disk in the Disk Manager.
Try to boot the computer with a special CD - any kind of Partition Manager (Partition Magic ?) and inspect the disk.
The Filesystem must be: Fat32 or NTFS, otherwise its not readable for Windows 2003.
Posted on Feb 20, 2009
    Scholar:
  • 77 Answers
Did you connect it to a spare IDE cable or an existing cable which was connected to the first hard disk or CD Drive?
Is BIOS able to recognize it? Go to the BIOS settings and check.
But since you are able to see it in the disk manager, it should be connected okay.
This is a new drive right? So what is the problem in deleting the existing partition and recreating it? BTW, what is the partition size?
Posted on Feb 17, 2009
Second hard disk drive not detecting
make sure you have the second hd set to slave
Jan 31, 2013 | Dell POWEREDGE 2900 Server
How to format IDE hard drive?
This drive is an IDE drive. The jumpers can be set on it to make it a slave.
Once set as a slave, you can identify the drive letter given to this drive and format it either at a command prompt: C:> format [drive:] /s (to make it bootable) or no /s to just format it.- OR within Windows: right click on the drive letter and select format.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Segate 1TB not working with Windows 2003 Server
Is this an internal disk, or an external backup device? Two possible routes:-
Internal disk:-
Ok first thing: Does the BIOS see the drive? If not, try flashing the Server's BIOS to the latest version. Check that the system will support disks >500Gb. Try turning on LBA in the BIOS. It shouldnt affect it, but has been known to.
If its not showing here, its either faulty, dodgy cables, or not supported.
If its visible in the bios, great. Make sure you have at least one and preferably all the service packs installed. Gold (RC) only supports 500Gb drives.
Make sure you have Chipset drivers installed for the mobo. If its visible in the disk management console, then create a small disk, NTFS.
External backup device:-
Either you will need to install the software in 'compatibility mode' for xp, OR
dont use their software at all. Just plug the disk in, and it should appear as a removable device. Then use the windows backup tool to create a backup file on the external disk, and run a backup using that.
Jul 12, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
In my computer 40gb hard disk and there are four partision c,d,e,f, but my d drive in not open ,not formate what can i do.
dear sir,
40 gb hard disk is so less,
because of that your computer becoming slow..
but you can fix it in one way..
install the window xp again, and this time just format which drive you want or else make two drive only.
or tell me d drive is NTFS OR FAT
if you dont know how to format
http://www.youtube.com/watch?v=dXqqLPa0ijk
Jul 03, 2009 | Microsoft Windows Server Standard 2003 for...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
Jun 19, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
Microsoft Windows Server Standard 2003 for PC Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
