Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
My 32'' sony wega blinks 5 times
My sony wega does not get a picture and blinks 5 times.after unplugging it i will get the sound back temporeily and then nothing and it blinks 5 times used to blink 7 but i unplugged it overnite and then it worked for a few weeks
sony wega kv-32xbr 400
    President:
  • 2,992 Answers
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Posted on Feb 17, 2009
Same problem...2005 Sony Wega 32"....LED
I've seen these melt internally. All i did to fix it was replace the under rated wiring with a thicker wire and it solved my issues. It was in an area with 3 plugs internally and I believe they were colored blue yellow and black.
If this was helpful please rate!
Mar 04, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
My sony kd32fs130 red light blinks 5 times
your video circuit is not working that is why you are not getting picture
Jan 29, 2009 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Sony KDF- 42WE655 Blinks 6 times No picture or sound
was there a smell? it might be main transformer the front blinking led means the set in is safety mode and wont boot up because of a fault
Aug 25, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have the sony trintron wega 32 hs 500
Seven blinks indicates a high voltage shutdown which has exceeded 33,000 volts and immediately sends the unit into a safety shutdown. In this case you would need to check the power supply regulation circuit and horizontal circuit for the failure. It could be as simple as the horizontal output transistor having failed to something more complex or expensive. Need to have it diagnosed for that to find out.
Bill
Apr 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega wont go on
Hii....
When the " SONY Bliking Codes " generated the circuits self diagnostic to trigger the pulse because some error accure....5 times blinking mean there's something wrong whit RGB level,the level not balance after 2 second due at first time the tv on...the protection circuit will send the error report,the tv will have no picture or sound....you will need to check at M board there's much things you have to do...
Thanks
[Vrya]
Mar 21, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony KV-32FS120 No picture, No sounds, 5 red blinks after turned on
your problem is in power supply section in your tv. if it is ok check for h/output section. call skilled tech to fix it it is not a major problem.
Sep 28, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv problem
5 times blinks is due to flyback transformer faulty or the short circuit in C board section.
Sep 14, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Black screen
If the power supply IC (MX0842) shorts out, it blows the Sony 0.1 ohm fuse resistor. The set will click but have no sound or picture and the LED will blink 5 times. The power supply should be repaired by someone with experience with Sony TV's.
Jun 17, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
2,752 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
