Question about NexxTech DP3222 DVD Player
I am trying to hook up a Nexxtech dp3222 disc player. The problem is that I have digital cable and I don't know how to hook the player through the cable. Also I can't find the universal remote code for the COX remote that I have.
  • 2 more comments
  • kellzely Feb 17, 2009
    I think you may have misunderstood my question
    I am not sure how this rca cable thing is going to work. could you explain it to me in more detail. will I still be able to use the digital cable if I get an rca cable. I am not that good at these things and need more detail.
    thanks the website was helpful
    I want to thank everyone for working on this problem. getting ready to watch a movie right now.
    President:
  • 2,110 Answers
Posted on Feb 17, 2009
    Guru:
  • 832 Answers
Hey there! thanks for using Fixya.com!
got this steps and hope this will help you. Just pe patient alright! its kinda long but i am sure that it will help you a lot!
Know how you are going to arrange/connect the wires and devices (also know what type of cables are needed, such as: coaxial, S-video, RCA patch-cords, etc.), and how they will be stacked, arranged or otherwise situated when you are finished. This foreknowledge will prevent a frustrating do-over.
  1. Connect the "tv out". On the back of the cable-box/vcr there will be 2 coaxial hookups, labeled "cable in" and "tv out" or something similar. The "cable in" (cable box) gets hooked to the cable jack from the wall or floor. Connect the "tv out" (cable box) cable to the "in" on the VCR. Connect the "out" (vcr) to the coaxial connection on the TV.
  2. Connect the red, white, and yellow colored RCA patch-cords" or an S-video cable (small, round ends with little pins and a piece of long, thin plastic [or a "fin"] inside). These cables should have come with the DVD player. If not, you can buy them at any store that sells electronics, such as Radioshack.
  3. Check the back of your TV to see which type of hookups are available and use the appropriate cables. Make sure that you are going "out" of the DVD player and "in" on the TV. These should be labeled as well.
  4. Plug everything in to test. Make sure that your TV is on the proper channel for the cable-box and VCR (usually 3, sometimes 2 or 4). The VCR should be on the same channel (for recording purposes.) When the VCR is off, you are watching cable. When the VCR is on, you are watching a tape.
    • The DVD player will be found on an alternate "input" setting such as "video1", "svideo", etc. depending on the input and type of TV.
  5. Stack your components however you wish. (see the warning about blocking vents) and power them up.
  6. Sit back and enjoy!!
Alternative Method
  1. Hook up a 3 way splitter to the wall cable outlet.
  2. Attach 3 RF coaxial cables to it.
  3. Connect one cable to the (in)on the cable box.
  4. Connect one cable to the (in) on the vcr.
  5. Connect one cable to the (in)on the tv.
  6. Connect the Svideo cable from the cable box to the tv.
  7. Use red white and yellow audio and video and cables to go out from the vcr, into the tv.
  8. Use red white and yellow audio and video cables to out go from the cable box into the tv.
  9. If S video cable is connected (#6) the yellow video connection from cable box to tv is not used.
Tips
  • RCA patch-cord cables are color coded: red & white are for audio (red is for right channel, white is for left channel) and yellow is for video.
  • If you are still having problems, call your cable provider and ask them to send a technician to help connect them. There might be a small charge, but it might be worth it.
Warnings!!!!
  • Be sure to unplug components before changing connections to avoid power surges that might damage the delicate electronics.
  • Be sure that all of your components have room to "breathe." Any openings in the case of your equipment is there to prevent overheating. Don't cover them up!
REgarding your universal remote code for the COX remote:
I have some steps again:Turn on the TV, VCR, DVD, or entertainment center that you want the remote control to control.
Step 12On the remote control, press the appropriate mode button for the device once.
Television TV
Stereo amplifier or receiver AUX
DVD, PVR, VCR DVD Step 22Press and hold the SETUP button until the selected mode button blinks twice, then release the SETUP button. Step 3Using the number keys, enter 9 - 9 - 1.
Result: The selected mode button blinks twice. Step 4Aim the remote control at the device, and then press the POWER button once. Step 56Press the CH+ (or CH-) button one or more times until the device turns off.
Notes:
In search mode, the remote control sends IR codes from its library to the selected device, starting with the most popular code first.
If, while pressing the CH+ button, you inadvertently pass the code, press the CH- button one or more times until the TV turns on. thenPress the SETUP button once to lock in the code.
Result: The selected mode button blinks twice. then8To search for codes for other devices, repeat steps 1 through 7.
Or you may go to this website for easier reference
http://www.ehow.com/how_4714859_program-cox-universal-remote-control.html
thanks again! i hope i helped you on this!!
Cheers!
Don't forget to mark!!
window.google_render_ad();
  • 10,594 Answers
Please check at rear of TV and DVD Player for Yellow-Red-White connectors (female pins) if these are available, calls RCA pins, then hook TV and player with RCA cable (male pins) yellow to yellow, red to red and white to white.
  • 265 Answers
You will need a Digital Optical to Coaxial Converter. Please click the link :)
Problem solved
Hope It Helps
  • Alex Keen Feb 17, 2009
    or another way of doing this is using a phono cable This is simply red and white audio out on the dvd player to audio in on the TV
    Digital optical sockets are normally hidden under a little black plastic plate, just pull to remove
    Brigadier General:
  • 3,614 Answers
Use a RCA cable, and connect the dvd player into a RCA jack input from your tv.
  • NexxTech Master
  • 19,396 Answers
Turn off both TV and dvd and connect the digital cable.
Dvd player keeps showing no disc
Check and replace its Laser Pickup unit. It is faulty. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Nov 12, 2011 | NexxTech DP3222 DVD Player
Hi, I need a 5 digit remote control code for a Nexxtech DVD player with 5.1 speakers. Thank you.
Using only the remote control do the following: open tray, then press on the remote, stop-2-3-7-9, press arrow down until 0, then press OK.
Jan 22, 2010 | NexxTech DP3222 DVD Player
How do i hook up to my tv?
It is very straight forward it all depends on the connections your tv has. If you know the model of your tv I can give you more specific directions. Basically just take color coded cables, connect from the output of the dvd player to the input on your tv. If you need any further assistance please let me know.
Thank you,
Lee
Dec 12, 2009 | NexxTech DP3222 DVD Player
DVD Player N715-PD NX
It's quite possible the laser isn't moving properly in the player or it can't read the index on the DVD because the lens can't see it.
If it's still under warranty, it could be returned.
Sep 16, 2008 | NexxTech DP3222 DVD Player
Try a Laser Lens Cleaner disc.
It is a CD with brushes on the bottom to help clean the laser lens (used for reading discs).  It can be found cheapest in grocery stores, then office supply stores, and finally most expensive in electronics stores.  It will usually run you about five to ten dollars,and can be used multiple times on any disc drive.
Aug 13, 2008 | NexxTech DP3222 DVD Player
Open tray, press on the remote, stop-2-3-7-9, press arrow down until 0 and press ok.
Make shure you put TV TYPE --> ntsc in the general setting
I tried this (on a multisystem set that can be "made to think" that it's a PAL or NTSC set as the case may be) and it worked. The Nexxtech DP3222 and the Entiveo DP3220 are basically the same unit except that (a) the hack for the Nexxtech doesn't require resetting every time you turn the unit on and off, unlike the Entiveo (this is really annoying) and (b) you can set the Nexxtech to multisystem, NTSC, or PAL standards, whereas the Entiveo is NTSC-only, but (c) the fast-forward on the Nexxtech is somewhat less intuitive than on the Entiveo (involves holding a button down). All in all, I prefer the Nexxtech, if only because it is more easily hackable. And I would have sworn that the Nexxtech had a blue screen saver on it before I started hacking it, because now it has a really gross-looking black-and-white screen saver. But I don't care about screen savers as long as the unit does what I want it to do.
Jan 28, 2008 | NexxTech DP3222 DVD Player
Freezing
damaged or dirty disc-clean or replace
ron
Dec 27, 2007 | NexxTech DP3222 DVD Player
Remote code #
I have just bought a GE Universal remote control and after playing with the codes and my Nexxtech DP3222, I have found the working code for the player. The code from my GE Universal 24921 for the DP3222 is 0956. The remote is sold in Walmart for a cheap price of US$4.96. I hope this info helps.
Nov 15, 2007 | NexxTech DP3222 DVD Player
Nexxtech DVD Slimline model DP3222
Could be an open internal fuse or power supply failure
Jun 04, 2017 | NexxTech DP3222 DVD Player
NexxTech DP3222 DVD Player Logo
37 people viewed this question
Top NexxTech Televison & Video Experts
jasbo
jasbo
Computer Repairing
Computer Repairing
Tygh Duval
Tygh Duval
Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
