Question about Toshiba TP55F80/81 55" Rear Projection Television
Tp55f80 tv. to much red on screen
We are having problams with heavy red lines above everything. When we first turn it on its fine for awhile then then start showing up and it makes it very hard to watch. any ideas?
    Novelist:
  • 184 Answers
You have a convergence failure. It may be possible to simply re-solder the pin connections under the convergence output ICs as they have a tendency to develop cold solder joints which cause intermittent mis-convergence. If the solder connections are good, then replacment of the ICs will be necessary. Expect to pay $350-450 to have a toshiba servicer fix this.
michtech
Posted on Feb 17, 2009
My TV has been in storage for awhile and when we got it home we had a blue screen then it turned off. Now when I turn it on I get a red screen which turns off within seconds.
Ur tv work before it in storage?The storage u put ur tv in,the place is very hot or very cold?U have a good and protections in heavy duty box the tv was in?Take the tv backcover off have an air compressor,have a good cleanning the internal.Tries the tv again.
Apr 23, 2010 | Sony KP-51HW40 51" Rear Projection...
WHERE CAN I FIND AN ORIGINAL REMOTE FOR MY TP55F80?
The problem is probably that one or both of the STK convergence chips have failed. These control the convergence coils around the red blue and green guns and are the most common cause of sudden convergence problems and the protection circuit shutting the TV down when turned on.
I can post details of how I replaced these on my Toshiba 40WH08B. Yours should be similar.
Mar 02, 2009 | Toshiba TP55F80/81 55" Rear Projection...
RED SCREEN
hell yeah,
the biggest mistake I did with this tv.all tubes need to be replaced and it burns a hole in ur pocket.no guarantee on tubes,sony aware of the problem but didnot recall these defective sets.
good luck.
nanz
Oct 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Convergence issue
Replace both convergence ICs number STK392-020 you can get replacements at the following link and they provide free instructions woth pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/
May 14, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Red Screen with Vertical Concave Lines
Check the transistors and resistors on the CRT socket circuit board itself. Also try turning down the red drive a little this may eliminate the lines.
Feb 02, 2008 | Toshiba TP55F80/81 55" Rear Projection...
Gun problem
Bill, the picture tells the story, you`ve lost convergence, either the convergence IC`s have failed or theres a slight chance that one of the convergence plugs got partially pulled out when you moved the set, of course the latter would be the easy fix, remove the back of the set and check all the plugs by pushing down on them or of course if you see one laying out of the plug just plug it back in. If the IC`s have failed or possibly the solder is broken on the IC`(s) and you are proficient with a soldering iron you can try re-soldering the pins, be prepared to lay on the floor for awhile there are 18 pins on each IC. check the plugs first (unplug the AC cord first), let me know if you know how to solder & unsolder and we`ll go from there, not much room on here to type in everything in one reply. BMW Rider
Dec 02, 2007 | Toshiba TP55F80/81 55" Rear Projection...
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
TP55F80/81 55 in
no mater what I say you will need a tech, is note that you dont have experiece with this tv, so let the job to a tech, is better for you...good luck
Aug 09, 2006 | Toshiba TP55F80/81 55" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
