Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Lamp flashing, replaced lamp not long ago?
Well, I am getting real tired of this T.V. If it's not one thing it's another
We replaced the lamp not too long ago. Yesterday the clean filter prompt came on, so we cleaned it. No picture now, the lamp light is flashing. Pulled out the lamp & it looks good.
Any ideas?
I ended up replacing the large fan on my mine and now it works great.  Was a little tricky getting it out of the cabinet, you have to loosen the wire clamps to create enough free slack in the wire to be able to pull the wire far enough to get the fan out.  If you're familiar with a screwdriver, you should be able to get it fixed easily enough.  You can find the fan on the panasonic support website.  Part number is FBL12G12LS.
Posted on Mar 19, 2009
PANASONIC PT-61LCZ70 when the set is turned on it takes a minute to power up then its on for a few minutes then the picture and sound turn off and the green power light flashes 25 times and the set turns...
Hello, have you replaced the lamp, it sound like the lamp is failing, it may also need the fans cleaned (the main reason for pre-mature lamp failure). Replace the lamp with a genuine Panasonis or Osram lamp only....tks
May 26, 2014 | Televison & Video
Lamp was replace, color wheel and now ballaster and now the bulb does not turn on.
the only thing I can think of is be sure the safety switch on the back is not your problem.
Mar 12, 2012 | Televison & Video
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
I have a sony model kdf60wf655. i replaced my lamp nearly a year ago, but now i have black screen, no sound, and the lamp light is constantly flashing red. please advise how to fix.
Lamp light constantly blinking shows that lamp is dead/ broken. If any thing else like ballast supply etc become defective, standby light will start flashing in specific order.
Replace lamp and make sure to get Son original replacement lamp to solve the issue.
Thanks.
Oct 28, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
We replaced the lamp about 6 months ago..but now it cuts off randomly..the red light and one green light will flash? Lamp replacement was when all 3 lights were flashing. Suggestion?
Is the picture quality good if it is then the lamp is ok try to reset the lamp timer if you haven't all ready. I think that the problem is coming from the ballast board this is the power source to the lamp, with time this part starts to ware out and starts to get weak. that is the reason your lamp does not stay on
Sep 07, 2010 | Samsung HL-S5686W 56" HDTV
Turns off/on every few minutes
I would replace the Lamp. This is a common symptom when the Lamp is failing.
I hope this helps,
Skyassoc
Oct 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
50? Samsung DLP TV Model #HLR-5067W
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
Oct 19, 2008 | Samsung DLP HL-P5663W 56" TV
Lamp automatically turns off
Hi there
Did you reset the lamp timer ?
Jan 24, 2008 | InFocus IN72 Multimedia Projector
Lights flashing and no piture or sound
I had the same problem a little over a year ago. It was the lamp. It needed to be replaced. I hope you have the extended warranty.
Jan 08, 2008 | Hitachi 50V720 Television
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
150 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
