Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven temp will not exceed 350 deg, also the timer does not work
I have a Magic Chef [ model 6498VVD ] slidein gas range purchased Feb. 2000. I had a new igniter replaced in July 2008. Now the oven temp will not heat higher than 350 deg and must press down arrow to start, plus the broiler works only on low and must also press down arrow. Is it practical to pay for service to replace defective part? New slidein gas ranges are priced over $1000. A service call is $75 just to walk in the house to tell me what I already know.
  • GE Master
  • 3,361 Answers
Check the oven temp sensor with OHM meter. It should read 1100 ohms.
If not, replace it.
Otherwise the electronic control is bad.
Posted on Feb 21, 2009
Using the oven with timer and how operate
Hi, you need the correct model number for your magic chef range/oven and repost, or go direct to magic chef's literature website: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=MCF
Dec 11, 2010 | Magic Chef 31000 Gas Kitchen Range
Whe i set the oven to 350 it has an F3 and wont light. This is a magic chef gas pioltless stove
Hi ttommajor,
The F3 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
Nov 26, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven is not reaching proper temperatures
You most likely have either a faulty thermistor or heating element that will need to be replaced.
Nov 10, 2009 | Magic Chef Kitchen Ranges
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Get too much of a gas smell when Magic Chef oven prheats up.
gas does NOT take that long to heat up!!
Shut that thing off before you kill your family !!!
Take it back or call someone to fix it !
This is a ticking bomb you have,...
If You smell gas then you should call the city or 911 .
Jan 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven does not heat up
I had the same problem with my magic cheff oven. I had to set the temp at 400 - 500 degrees to get to get an actual oven temp of about 250 degrees. The oven temp sensor checked ok with an ohm meter. Should be around 1100 ohms at room temp. I work in the electronics industry and know capacitors go out of range and dry out with heat and over time so I replaced the 3 or 4 electrolitic capacitors on the timer board. Cost me about $6.00 at Radio Shack and now my oven temp is right on the money. I realize not everyone may want to do this but it worked for me. Better than the $200.00 for a new oven timer control board. I have also found a company's website that fixes these boards for about $89.00 ApplianceTimers.com
Sep 09, 2008 | Magic Chef CER3740 Electric Kitchen Range
Pilot light out/will not go above 350
Sounds like the thermostat controlling the gas valve in the oven is not working, I’m trying to find if the oven igniter is electric, but believe the igniter is electric. If it does light then not regulate the temp above 350 degrees, I am convinced the thermostat control is bad.
Oct 23, 2007 | Magic Chef CGR3725 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
144 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
