Phone connection We have a fax machine that uses a cell phone for connection. the cell phone is analog and it no longer works. Is there a digital cell phone that we can connect the fax machine to? Thanks
    Genius:
  • 2,120 Answers
No, faxes are strictly analog
Posted on Feb 17, 2009
HP 2727nf fax machine Fax not working what is the problem ?
Get an analog phone to test your phone line first. Then, make sure this line is connected to LINE port on your fax machine. Use the same analog phone to connect to the EXT port to test the line again.
Use another line to call this fax number to see whether the analog phone rings. Once you know the line and connection is okay, let's reset your fax machine. See http://www.fixya.com/support/t2503076-hp_laserjet_m2727nf_mfp for the cold reset instruction.
Dec 13, 2016 | HP LaserJet 2727NFS All-In-One Printer
How do I connect A Epson WorkForce 845 to NBN & Telephone
If your phone is provided by broadband then it is now a VoIP phone. In order to use your machine, you will need a fax gateway or a digital to analog converter. This will allow your fax machine with uses a analog line to connect to a digital VoIP line. You will need to connect your nbn provider.
Sep 05, 2014 | Epson WorkForce 845 Wireless All-in-One...
Can no longer send/receive faxes since switching to digital phone
hi
fax does not work on digital line it only works on analog line........if u want our technician expert then contact us athttp://tinyurl.com/ldnuy2
Jun 21, 2009 | HP Officejet 6310 All-In-One InkJet...
I have cable modem for my internet. I dont have any phone service
No. fax machines are ANALOG devices. Cable Modems, DSL, Vonage etc are DIGITAL.
Feb 11, 2009 | Canon FAX-L350 Plain Paper Laser
Fax won't work with new digital/internet phone system
True. ALL fax machines are analog devices. Internet phone lines are DIGITAL.
There is no way to make it fax reliably.
Dec 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Send and receive speed
That's not even a coherent response. Even analog phones go from an analog signal from your home, to a digital signal at the carrier, to an analog signal at the recipients end. It all goes digital at some point.
Fax machines work fine with a digital phone. The baud rate may need to be lowered in some cases, but working for a cable company, I've personally worked with hundreds of fax machines that work just fine.
Try lowering the baud rate and/or using a DSL filter if you are having problems. If you are unable to find the baud rate or speed setting on your fax, you may want to contact Canon to find out how.
Dec 09, 2008 | Canon FAXPHONE L80 Laser
What kind of phone line?
ALL fax machines require an analog phone line. There are no digital fax machines.
Nov 12, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Lexmark x6150 unalbe to fax phone line is active using dsl
Hey Tony - Did you recently hook this up to the DSL for the first time? This unit is supposedly not able to work with a DSL line.
The fax modem in your AIO is an analog device and cannot be used on an ISDN, DSL, or PBX digital phone service. However, you can connect certain devices to your AIO that let you use the fax function in addition to these digital phone services.
To connect without an unsupported line:
Connect an active telephone cable from the AIO to the telephone wall jack.
To connect with an unsupported line:
If you use an ISDN phone service, you can connect to an analog telephone port (an R-interface port) on an ISDN terminal adapter.
For more help and to request an R-interface port, contact the ISDN provider.
If you use a DSL (Digital Subscriber Line) phone service, you can connect to a DSL filter or router that will allow for some analog (rather than digital) use.
If you use a PBX phone service, you can install an analog phone line for a fax machine.
If this was working on the DSL let me know. I don't know the location but obviously a separate phone jack is the easiest. Let me know. If this helps you fix it you can rate this as fixed. If you are just going to rate this as helpful I'd rather you please not rate it and just add a comment and say thanks for the info.
If you need more help just add a comment and I'll be glad to assist you further. Thanks.
Jeff
May 09, 2008 | Computers & Internet
Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
I get calls all the time about fax issues. I work for Comcast and have guided people to the right answers about third party devices. We use a digital connection. Analog is a dying medium. Most calls are concerning HP and Brother but I know others fax machines have had problems too. The new HP machines have a digital setting. HP is aware of digital issues and can help you. It is unfortunate that old fax machines are not digital but a new fax is inexpensive if you wish to buy one. Analog takes up too much space. An example: Six digital television channels can fit in the same space (bandwidth) as one analog. That is why the FCC mandated the change. The same goes for phone lines. I Google almost every problem concerning fax machines and if you go past all the upset comments you will get to the comments that offer remedy. I also wanted everyone to know that a second, no frills fax line from Comcast is very inexpensive and our way of offering a dedicated fax line intead of a distinctive ring fax option.
Mar 21, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
24 people viewed this question
jasbo
jasbo
