Question about Maytag MDB7100AWB Dishwasher
Brown deposit with shiny specks on floor of dishwasher after cycl
I noticed a funny taste to the cups a couple days ago...last night I noticed a brown powdery substance with shiny specks in it on the left side of the dishwasher floor after the cycle had just run. It came off onto my finger when I touched it. It was dry/powdery, not greasy and had metallic looking flecks that I couldn't feel when I rubbed my fingers together. It was by the float cap. Any ideas?
  • marg715 Feb 18, 2009
    It drains into the undersink plumbing. The brown is more a sludge and NOT rust. We've had the same set-up for 3 different dishwashers for 30 years! Our water is VERY soft.
  • Jim London
    Jim London May 11, 2010
    Hi, where does this unit drain?
  • 257 Answers
Hi, Nobody wants to give this kind of news but what you are describing is called effluent. It comes from the inside of drainage pipes. That is why I wanted to know where it drained, but specifically, so I could help you identify where the problem might be. This problem occurs when the drainage is too slow for the machine. You need to check all of your undersink plumbing, garbage disposal if you have one, at the very least pull the sanitary trap and clean it out. Once you have cleaned out what is slowing down your drainage, run the machine and check to make sure you have no residue as effluent is not sanitary. Good Luck to you!
Posted on Feb 18, 2009
  • 547 Answers
Rusty pipes pumping in rust from main
Posted on Feb 17, 2009
My coffee maker is making an unusual "squeegee" sound when heating the water.
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Jan 11, 2013 | Keurig Special Edition B60 Coffee Maker
GE fridge 1999 model. water started tasting funny. found black stuff in a peice of ice. Water in rest of house seems fine.
Hello there,
When your water starts tasting funny and you can see some kind of particles in the ice, then it means the water filter is dirty and needs to be changed. Try to get the water filter replaced and the funny taste will stop.
If you are having some kind of lime taste or mud taste, or lime deposits or mineral deposit, is simply means you will have to replace the water line and reservior.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Refrigerators
I have a Frigidaire dishwasher that's just over 1 year old and I use it a couple times a week. I turned it on last night and went in another room. appox 30 minutes later my daughter came in and noticed the...
Someone squirted dish soap in there instead of regular dishwasher detergent...
You will need to manually rinse out the soap and use the right soap...
heatman101
Sep 18, 2010 | Dishwashers
Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
Aug 01, 2009 | Keurig B50 Coffee Maker
Funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
Apr 03, 2009 | Cuisinart Coffee Makers & Espresso...
Black specks
is that a glass? can't tell. is there water curculating to the top rack? if not you probably have a bad chopper
Sep 16, 2008 | Kenmore 15899 Built-in Dishwasher
Dishwasher pump caviation
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Dishwashers
Metal Tasting Coffee
vinegar is not the best it remove calcium in little piece descaler produit melt go buy the descaler produit 1part descaler 1 part water put in water container start the machine after a few second turn it off leave it there for 15 minute repeat untill empty rinse very good after that product is corosif 2 or 3 full rinse thanks for using fixya pierre
Feb 12, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Maytag MDB7100AWB Dishwasher Logo
152 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
