Question about HP OfficeJet t45 All-In-One InkJet Printer
Fax line won't answer when set to double ring, beeps phone all rg
I recently changed my OfficeJet T45 from its own phone line to a shared line with custom ringtone. The machine was originally set to answer all rings, but in this setting it continues to beep through conversations on the phone. When I went in to advanced fax setup and changed to double ring, the fax machine doesn't recognize it and answer. I have tried, single ring, double ring, triple ring and both double and triple ring. The only way it picks up is in all rings and I'm back to the original problem of the fax twitter thing through the conversation.
  • 14 Answers
SOURCE: How to prevent HP 3380 All in One Printer answering voice calls
If you have call waiting on your phone service you can call your phone company and get "personal ring" service. It will cost a couple of dollars extra a month, but they will assign you another phone number and it will have a different ring style to it. Then you can set the ring type to the type of ring they assign you.
Posted on Jun 02, 2008
  • 137 Answers
SOURCE: me again 2210xi all in one fax problem
The "tags" says no dial tone, so I wonder if you can send faxes? If not I would suspect the connection is not correct. The preferred setup would be to connect the phone line from the wall to the line input of the 2210 and then plug the phone (and answering machine) into the phone output on the 2210. Looking from the back the should plug into the jack on the right and the line to the wall should plug into the jack on the left. It is possible (??) that the 2210 will not present an autoanswer option if an active phone line is not connected. You can see the setup instructions for the Fax here. Note HP recommends using only a 2-wire phone line.
Also, do you have DSL on the same line? This can cause some issues.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jul 03, 2008
  • 111 Answers
SOURCE: Fax Duet Setup
Not sure this will help but you could give this setup guide a try and see:
Setting up fax to use DSL
Post back your results, particularly if you need more assistance. Good luck.
Posted on Oct 15, 2008
leroyal
  • 2120 Answers
SOURCE: HP 7280 fax interrupts phone calls
Set the fax to MANUAL MODE, you will then have tp press START to receive a fax.
Posted on Dec 21, 2008
  • 37 Answers
SOURCE: fax answers on phone calls.
Hello There. Most household all in one units cannot operate on the ring characteristcs that you are describing.
They simply operate on the number of rings before automatic pickup to the fax machine. Therefore, you will need to just change the number of rings before the fax machine picks up. In this case however, you will not be able to use voicemail, since one or the other will will pickup.
http://h10032.www1.hp.com/ctg/Manual/c01102249.pdf
Page 63 and 64 (in PDF) or page 62 and 63 (hardcopy manual) explain the process.
Ignore the information about setting higher then voicemail. That information is typically only valid if you have the old voicemail devices in your home. Most people now adays get a voicemail service added to your telephone service, in which case you cannot control the voicemail as easily.
So again, in other words you will be sacrificing your voicemail for your fax machine. Only other way around it is to get a dedicated fax line to seperate the two numbers.
Posted on Feb 26, 2009
Fax won't answer
If you have an answering machine connected to the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated to the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Hi my hp 640 will not answer a fax call, but will answer only if we pick up the hand set.
Issue When the all-in-one product is sharing a phone line with voice calls, some calls are interrupted by fax tones. Follow the steps below to solve the problem.Step one: Check the Rings to Answer setting If Auto Answer is enabled, the HP fax product will answer the phone line when the number of rings reaches the number of rings specified in the Rings-to-Answer setting. When voice calls will be received on the same phone line as faxes, set to rings-to-answer to 6. If you do not want the fax to answer automatically, either turn off Auto Answer from the front panel and receive faxes manually (this may result in lost faxes) or subscribe to a distinctive ring service from the phone company (if available). Refer to the Answering faxes manually section below to learn how to answer faxes manually or refer to the Using distinctive ringing section below for more information about using distinctive ringing. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. The Rings-to-answer setting for the HP Officejet 500 and 600 series products can only be checked or set using the all-in-one software on the computer. Follow the steps below to check or change the setting for all models except the HP Officejet 500 and 600 series:
  1. Depending on the model, press either Menu , Setup , or Fax Setup repeatedly until Basic Fax Setup appears in the display.
  2. Press Enter (or Start or OK ).
  3. Press the right arrow button repeatedly until Rings to Answer is displayed, and then press Enter .
  4. The number of rings before the HP fax product answers will be displayed.
    • The setting is correct if it is 6. Press Cancel or Stop (Stop Fax) to exit the menu.
    • If the number is not 6, press the right arrow button until 6 appears in the display and then press Enter (or Start or OK ).
Aug 30, 2011 | HP 640 Inkjet Fax Machine
I have changed from a desinated fax line to sharing a phone and fax line. the fax machine rings along with the phone however the fax does not answer. i was told to purchase a ring decipher but cannot...
Your fax can share the line with your phone, but it needs to be set to answer or not, depending on your equipment and choices.You can download the manual from Brother here. The receive modes are explained on page 5-1.
If you're often out when faxes or phone messages might come in, you probably need to plug an answering machine into the back of the fax (the EXT. jack) and put the fax in FAX / TAD mode. (TAD stands for Telephone Answering Device. Be sure the TAD is set to answer before the fax does. The fax will pass the phone call through to the TAD, and if it hears the beeping of another fax sending, it will cut off the TAD and take the call.
See the manual for more info and other options.
Feb 15, 2011 | Brother IntelliFAX 2600 Fax
Will not accept incoming faxes
Have you set the Fax to Auto-answer or is it waiting for you to manually answer the fax? Change this by pressing Setup and Press 3, Press 3 again. Press the right arrow to toggle On or Off.
Make sure that the rings to answer is set appropriately. Press Setup 3 4 to change.
If you have a PBX or ISDN converter phone system, check that you are using the correct phone jack - for phones and faxes.
Do you have a voicemail service on the line? This will force you to receive faxes manually and only when you are present.
If you have an answering machine connected to the line, check that the answering machine is not the problem by disconnecting it and trying to receive a fax. Long welcome messages can make the calling fax machine hang up early. Insufficient time between the end of the message and the beep can make it impossible for the OfficeJet to spot the fax tones; the same is true with loud messages.
If this is the problem, record your message again, keeping it short (10 seconds but speak softly and slowly).
If you have a distinctive ring on the fax line, make sure that the OfficeJet is programmed to recognize the ring (some ring patterns cannot be interpreted and you'll need to contact your phone company to change it).
Check that other computer hardware is not causing an issue (modem with auto-answer, other interference). Unplug everything except the OfficeJet and try to receive a fax to check for interference. Then reconnect one item at a time and try getting a fax again to determine which item is causing the probelm.
I hope this helps.
Apr 08, 2010 | HP 5510 4-in-one Printer
How to set fax machine so it can accept after 2 rings?
Distinctive Ring basicsDistinctive Ring service is an optional service available from many telephone companies. The Distinctive Ring service permits you to assign more than one telephone number to the same telephone line. Distinctive Ring allows you to use a single phone line for both voice and fax calls. You can assign a unique phone number and ring pattern for incoming fax calls. When a fax comes in, each telephone number makes a distinctive ringing sound, such as a single ring, double ring, or triple ring.
NOTE: The Distinctive Ring Service is the name HP and others use to describe this feature. Distinctive Ring is also known as:
  • Call Sign
  • Custom Ring
  • Ident-a-Call
  • Ident-a-Ring
  • Ident-a-Ring
  • Multi Ring
  • Personalized Ringing
  • Ringmaster
  • Smart Ring
  • Teen-Ring
The Distinctive Ring Service allows the HP product to work similarly to a dedicated fax line. If you connect an HP fax product and a telephone to one telephone line, you can assign one telephone number for fax calls and another for voice calls.
NOTE: You cannot send or receive faxes when the phone line is in use. Even if the HP fax product has a separate telephone number, it is still sharing the same phone line. Set the Distinctive Ring Service Using the menus on the product control panel, follow these steps to set a distinctive ring pattern. Step one: Turn on Auto Answer Turn on Auto Answer by pressing the Auto Answer button on the control panel. The button light indicates when Auto Answer is on.If the button light is already on, you do not need to press the button. Step two: Set the distinctive ring patternFollow these steps to change the answer ring pattern.
  1. Press the Setup button (c01461502.gif ) on the product control panel.
  2. Press the Right Arrow button (c01185072.jpg ) to select Advanced Fax Setup , and then press the OK button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Distinctive Ring , and then press the OK button.
  4. Press the Right Arrow button (c01185072.jpg ) to select one of the following options:
    • All Rings
    • Single Rings
    • Double Rings
    • Triple Rings
    • Double & Triple Rings
  5. Press the OK button to select the option.
  6. Press the Back button (c01490920.gif ) to return to the main menu.
Now if you have anymore problems copy the link from below and paste it in your address bar and it will help you further with a document. Follow all the settings in the document and your fax should be setup,keep in MIND THAT THE RINGS TO ANSWER SHOULD BE 2,SO YOU CAN RECEIVE FAXES AFTER TWO RINGS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01647469&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3795406
Feb 01, 2010 | HP Officejet 6500 Wireless All-in-One...
How do you set up fax phone on the HP officejet 6215
hi you really have a very good choice of printers is one of the best printers from hp
inorder to set fax on ur printer you should first be sure what type of telephone line you are using
there are 2 type of line 1 dedicated -> that is directly attached for fax and has no other telephone or TAM connected if you have this line you can directly attach the phone line on the printer line 1
the other type of line is shared that means you use the same line for phone and fax in this the connection should be as :- telephone line from wall jack to the printer line 1 then from printer ext port to telephone answering machine (if any ) then from answering machine to telephone (if u have a dsl line that means u use phone and internet from the telephone line then there will be 2 lines comming out of the splitter 1 to router and other to telephone here follow the shared line connection mentioned above using the line that goes to the telephone )
now power on the printer and press the setup button (menu) now navigate to basic fax set up press ok and then go to rings to answer it should be 4 rings now go back and go to advance fax setting and then to distintive ring (DRP) select all rings and press ok now run fax test if it passes then ur fax is set up try sending fax now hope this will help you
Jul 22, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Fax does not connect on distinctive ring
It's either your phone, or it's your fax machine that does not support fax through phone.
Jan 30, 2009 | HP Officejet 5610 All-In-One InkJet...
I can send faxes, but cannot receive faxes.
Thank you for specifing your connection>
When you have a shared fax line it is import to have a Distinctive Ring Pattern which will differenciate the type of ring patter to recieve voice calls and Fax message.
All You need to do is get a distinctive ring pattern from your telephone service provider (AT&T) and setup your fax machine as per the ring pattern provided by your service provider.
All you need to do is set your rings to answer in youe phone to Rings 4 in your Phone.
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate basic fax setup> Press Ok and set the Ring Pattern to Number 5 or 6> Press Ok and cancell to come to the main menu
Then in the All-In-One Go to menu / Setup> Press the right arrow key and locate Advance Fax Setup> Locate Distinctive ring pattern and set it to the ring pattern which your Telephone service provider has alloted i.e Single Ring, Double Ring or or Triple Ring (Whichever is applicable)> Nd press Ok and cancell to come to the main menu.
Then you will be able to receive fax message voice cals and voicemail without any interuption.
Good Luck
Sep 25, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Faxing
To fix this issue I would need some more information,
1. Is it a dedicated phone line Or sharing phone line?
2. If it is a sharing phone line then do you share it with an answering machine or a voice mail?
3.If it is an aswring machine or voicemail.. then how many rings has it set to answer?
Aug 25, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
HP OfficeJet t45 All-In-One InkJet Printer Logo
187 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
