Have a Denon DCD-520 and it skips forward and back while playing
Hopefully, it may just need cleaning and lube.
I have a Denon DCM-460 purchased from Goodwill a couple days ago and had problem with one CD-R skipping and stuttering toward the end.
Cleaned the CD which helped a little but still started skipping and stuttering.
Noticed a scratch toward the outer end which I suspect is where the problems occurred.
Anyway, last night I cleaned laser, rails, lubed spindles and moving parts. I used 99.9% alcohol to clean. I used a light teflon oil (Tri-Flow) to lube spindles and rails. And white electronic grease where you see remnants of white grease.
Today, I now played through the problem CD-R with no problems.
Assuming placement is level and stable, certainly worth a try and the effort.
