Question about HP DeskJet 5550 InkJet Printer
Cutting off top of line of print but only an occasional line.
I just installed new ink Cartridges; OD 56 and OD 57. The cartridges say "replaces HP 56" and replaces HP 57". Most of the lines of print come out fine but occasionaly a line will have the top of the letters missing for the entire row, then the next line returns to normal.
    Genius:
  • 2,120 Answers
Cart is Dried up inside
Posted on Feb 17, 2009
Hp 2540 deskjet. Just replaced BOTH cartridges with genuine HP ink 60. Printer still flashes on the cartridges being empty. Error message. I cannot print anything. I can scan but that is all.
Per HP: After installing a new print cartridge, a message appears on the front panel that the print cartridge is low on ink. This may be caused by installing the cartridges with the power turned off. Cartridges should always be installed with the power turned on.
Found the following directions online:
How to Replace an Empty Ink Cartridge in the HP Deskjet 2540 All in One...
May 20, 2016 | HP Office Equipment & Supplies
HP all-in-one F380 only prints top half of the page, and sometimes that is pretty faded. What to do?
Replace the ink-cartridges, because they are just about empty.
When ink is pulled from the cartridge, there is just enough ink to print a "low-density" page,
or a few lines of text, but there's not enough ink to "freely" flow, on demand, to ink a full page.
Jul 30, 2011 | HP DeskJet F380 All-In-One Printer
The black printer cartridge leaked a fair amount of ink in to the printer. I am getting all lights flashing and the printer won't even turn off when I hit the power button. I did some cleaning and it...
Sorry to hear that.. here are some instructions that should help you out:
Instructions
things you'll need: Microfiber cloth
1. Ink Cartridge Errors
2. Turn the printer on and open the ink cartridge cover. Wait for the cartridge carriage to stop completely before reaching into the printer.
3. Press on the top of each print cartridge, then pull the cartridges free from the carriage. Make sure you are only using HP cartridges labeled as "HP 60" or "HP 60XL."
4. Reinstall the ink cartridges and close the cover. If the ink cartridge error message displays again, remove the ink cartridges as before.
5. Clean the copper metal contacts on the cartridges using a dry microfiber cloth. If you still see the error message after you reinstall the ink cartridges, replace hem with new cartridges.
Print using the device's ink backup mode if you do not have a replacement for one of the cartridges. Remove the cartridge you cannot replace and close the cover and continue printing. The printer will automatically use the backup mode until you install a new cartridge.
Mar 21, 2011 | HP DeskJet F4280 All In One Printer InkJet
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
The HP All-in-One prints a print cartridge alignment sheet.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Align the print cartridges
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
cartridges ensures high-quality output.
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Dec 04, 2009 | HP Officejet 4315 All-in-One Printer
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Regards,
Shrey
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
How do you change an ink cartridge on a HP officejet 5510 printer?
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Aug 11, 2008 | Office Equipment & Supplies
How do I install an ink cartridge? HP photosmart c5280 All in one
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
  4. Pull the print cartridge toward you out of its slot.
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
May 15, 2008 | HP Office Equipment & Supplies
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP DeskJet 5550 InkJet Printer Logo
218 people viewed this question
Ben Johnson
