Question about Sharp AL 1631 Copier
1/8 black lines on Sharp AL-1631 copier
I have tried several suggestions on this web site to no avail. My problem is that the lines appear only when I feed the paper using the overhead document feeder and not when ther paper is placed on the platen. I have cleaned all that is visible to me. Any other ideas?
  • jcruisenet Feb 28, 2009
    You are a genious! Problem is fixed.
    Thanks
Have you cleaned the narrow glass next to the platen where the originals are scanned across when using the auto feeder?
Posted on Feb 26, 2009
AL-1631 is flashing "H". How do I fix this which appears to be heat related.
the h means that your fuser needs to be replaced. it might be fixable by changing the thermal fuse but most of the time the whole fuser needs to be replaced
Sep 28, 2014 | Sharp AL 100DR Laser Toner Drum Works for...
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
SHARP AL-1631 COPIER NOT RESPONDING
try re-installing the software, and re-post if necessary
May 14, 2009 | Sharp AL 1631 Copier
Sharp al-1631 lines on copy only when original goes through docum
Clean the narrow document scanner glass to the right of the main copy glass.
Mar 11, 2009 | Sharp AL 1631 Copier
FEED ROLLER Sharp AL-1631
Percision roller phx arizona also have web sight
Dec 26, 2008 | Sharp AL 1631 Copier
AL-1631 Copier puts a black line on each page
does the line go across the page & move ? then your drum needs to be replaced.
Dec 01, 2008 | Sharp AL 1631 Copier
Sharp Copier AL-1631. Copies with a black line (which moves positions on the page each time). Checked the manual and cleaned the part that it told me to. That did nothing to fix the problem.
If it only happens when using the document feeder (if fitted), then the small glass on the right hand side needs a clean ( normally tippex), if it occurs when copying from the glass and doc feed then your charge corna needs cleaning
Asharp AL-1631 won't print anything but a mess.
E7 is a few different things. Are there two more numbers flashing after the E7 appears?
F5 has to do with the copy lamp.
It should be looked at by a technician. It needs to be looked at for the E7 issues.
Jun 13, 2008 | Sharp AL 1631 Copier
Sharp AL-1631
Several things can cause this problem; The drum cartridge is not being cleaned properly or there is a problem with the toner cartridge . Take out the drum cartridge and inspect it for any signs of the defective image. If that doesnot solve the problem, then Call a tech.
Apr 20, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
88 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
