It is intermittent and seems to start by going onto different web pages
If the noise isn't coming from a speaker, you could need to replace the fan on your computer. The bearings for it might be busted, another issue could be the speaker wire isn't fully connected internally, which you could fix by popping off the top power panel area and fastening the speaker wire in it.
I hope this helps, if not I apologize. The question isn't super vague, but it still has holes in it. :) I can to help more if you post more about the issue.
SOURCE: I have an Advent 4211c
sounds like windows is having an issue with stopping a program that is running at the time that u try to shut the computer down like what programs are running when u try the shut down
it can also be caused by a corrupt registry or something as simple as a corrupt driver
Testimonial: "Thanks very much... I'll look into that and make sure no programs are running in the back ground... THANKS !! "
