Question about Delta Machinery Delta ShopMaster DP350 12" Variable Speed Bench Drill Press, 500-3100 RPM, 1/3 HP
Delta drill press model DP350 went out while using it
The drill press was working fine and i turned it off aftter drilling some holes in some lumber. went to turn it on about 1 minute later to continue drill and nothing? There was no electrical shortage or anything it just will not come on. Can the on/off swith go out?
  • jharmonjr2 Mar 14, 2009
    I had a similar situation happen recently on this same drill press. I was told to check out the capacitor and it seems to be faulty. However I am having difficulty locating a replacement.
    President:
  • 1,902 Answers
Check for power at the on switch. The switch on this machine should be electrical so yes it could go out. If it is not the electrical type then I would check to make sure that the internal switch did not brake or go bad.
Posted on Feb 17, 2009
What can be used as a replacement for discontinued pulley part 904163
Take the old pulley to a shop where they sell pulleys and try to match it up. I did that with my lawn tractor and found one that worked.
Feb 18, 2015 | Delta Machinery Delta ShopMaster DP350 12"...
DP 350
A special kind of pliers are made for this that have tips that fit into the little holes near the gap in the spring clip. Harbor Freight sells one for like $10 or less. They have interchangeable tips that work for internal or external springs.
Good luck.
Aug 31, 2012 | Delta DP350 12 Variable Speed Drill Press
Power supply Delta DP350
If you go to http://servicenet.dewalt.com/ and put your model number in the search box, you'll be able to view/download the parts brakedown and owner's manual. You can order the switch from them or find an aftermarket parts place like www.ereplacementparts.com to get the switch.
Jun 12, 2012 | Delta Machinery Delta ShopMaster DP350 12"...
How do you remove the chuck from a Delta shopmaster 350 bench top drill press?
there is a "drift pin" that came with the tool, you would need to insert it into the slot and tap on it.
Sep 08, 2011 | Delta DP350 Shopmaster 1/3 Horsepower 12...
Delta 12" Variable Speed Drill
try cleaning the pulleys buy a good belt (gates) install belt and make sure you have good belt tension
Feb 06, 2011 | Delta Machinery Delta ShopMaster DP350 12"...
I need to know the price for this part No.905610 for a drill press 12inch DP 350 this part is damage along with the Motor Pulley part nos. 904166 and 904163
can you describe the part, the other part number you furnished are superseded with replacement parts and I can't find this one listed, let me know and I will try and help
Mar 07, 2010 | Delta Machinery Delta ShopMaster DP350 12"...
How do you ajust the high and low speed on the drill press
not sure if you have a dial on that press to adjust the speed. if it is a dial on the machine make sure you adjust it while it is running.... but it looks like it is belt driven and there will be a series of pullies under the top cover for adjusting the speed.
Mar 03, 2010 | Delta Machinery Delta ShopMaster DP350 12"...
Just got the dp350 can not get the chuch to stay on no matter what i do
try this, get something like brake clean or equiv. spray the inside of the chuck and also the spindle, wipe clean with a paper towel. fully retract the jaws and using a block of wood tap on the chuck to seat it on the taper. You might have to move the table out of the way but it will work. If I have helped you with your request would you please rate this response accordingly. Thank you
Nov 05, 2009 | Delta DP350 Shopmaster 1/3 Horsepower 12...
How to change belt
THERE IS A LITTLE HANDLE AT THE SIDE
PUSH IT UP THEN TAKE OUT THE OLD ONE
AND REPLACED
May 10, 2009 | Delta DP350 Shopmaster 1/3 Horsepower 12...
Delta Drill Press motor stopped running
I tried the model number listed and didn't find just a capacitor, but I would think that you would be able to find it at a local electrical supply house, one that specializes in service to the contractor, take that one with you and they should be able to match it up. If not give me the exact model number and I will try and find one online for you
Mar 14, 2009 | Delta DP350 Shopmaster 1/3 Horsepower 12...
Delta Machinery Delta ShopMaster DP350 12" Variable Speed Bench Drill Press, 500-3100 RPM, 1/3 HP Logo
510 people viewed this question
Top Delta Machinery Drills Experts
EugenesDIYDen
EugenesDIYDen
John Mock
Are you a Delta Machinery Drill Expert? Answer questions, earn points and help others
