Question about GE Profile Spacemaker Over-the-Range Microwave
Filter Change I had a warning on my read out that said that the chrcoal filters need to be replaced. So I purchased two like they recommened but where do they go? I take out the washable ones but I do not see where the charcoal ones go.
  • Mark Egan May 11, 2010
    Reply back your model number so your unit can be reviewed.
Take off the grill above the door - 2 screws and it is easily found behind the grill
Posted on Feb 19, 2011
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
Mar 14, 2014 | Maytag MMV5208W Microwave Oven
I need to change the water filter in my samsung srs618dp fridge freezer. I have the filter but cannot locate the internal part in the fridge i need to change.
For Samsung side-by-side refrigerators, there are two possible locations. One is in the upper right hand corner of the refrigerator. The other is behind the veggie drawer.
To access the filter, either remove the top glass shelf or the vegetable bin. Turn off the water to the refrigerator. If no filter is currently in use, remove the cap. If a filter is in use, remove the old filter. Turn clockwise to remove the old filter. Save the cap to reinstall if the fridge is ever used without the filter. Note the date when you put in the new filter and place the sticker on the filter. Remove the red cap from the new filter and align the unlock mark with the filter mark on the filter housing in the refrigerator. (Looks like an unlocked padlock with the u part turned 180 degrees from the rest of the lock). Turn the new filter counter-clockwise 90 degrees until the lock symbol (closed padlock) lines up with the mark on the housing. Use steady firm pressure - it will be hard to turn. This ensures a tight seal. Turn on the water line and check for leaks. If the filter isn't leaking replace the shelf or the vegetable drawer.
Samsung support for the SRS618dp is here: http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SP00&prd_ia_cd=2201&prd_mdl_cd=RS23DENS1%2FRAD&prd_mdl_name=SRS618DP&srchword=SRS618DP .
I hope this helps.
Jun 12, 2011 | Microwave Ovens
How do I change the filter on the Hotpoint RVM1535WMCo01 microwave oven. When I took the top off I can not see a filter to replace. Does that mean that I have been running the Micro for the last year...
Microwave ovens produce dangerous emissions and require servicing by qualified technicians.
I suggest purchase a new one rather than repair because most microwave models cost as much to repair as simply buying a new one.
Nov 02, 2017 | GE Hotpoint RVM1535 Microwave Oven
Where is the fuse located?
If the model number is correct, there is a small input line filter board with a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line filter is listed as item 1420. The fuse will be mounted to this board.
You can purchase replacement fuses at any hardware store. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 24, 2010 | GE JES1290 Convection/Microwave Oven
Message to change filter but unit exhaust up to stack?
Grease filters change from the bottom side of the unit.
Charcoal filter is changed as follows:
To Remove Charcoal Filter
To remove the charcoal filter, disconnect power
at the main fuse or circuit breaker panel or
pull the plug.
Remove the top grille by removing the screws
that hold it in place and sliding the grille to the
left (opening the door makes grille removal
easier). Slide the filter towards the front of the
oven and remove it.
To Install Charcoal Filter
To install a new filter, remove plastic and other
outer wrapping from the new filter.
Insert the filter into the top opening of the oven as
shown. It will rest at an angle on 2 side support tabs
and in front of the right rear tab. Replace the grille
and screws.
Aug 20, 2009 | GE XL1800 1100 Watts Microwave Oven
I need a charcoal filter
The GE spec sheets for what is the right charcoal filter are incorrect. You will never find the right one. I have this same microwave and had same problem. I called a local appliance company and they gave me Part No. WB06X10359 and when I googled this part it was not the right dimensions. I finally found the perfect solution. Go to www.rangehoodsfilter.com (Filter Factory-TTN Inc.) and they are customing making the filter for me. I spoke to Dave this morning from Filter Facotry and he's making me one with the following dimensions - 5 7/8" x 13 1/4" x 1/4". The cost is $16.95. If this fits I will order more. The more you order, the cost per unit goes down.
Jun 03, 2009 | GE Spacemaker JVM1540 Microwave Oven
Need to clean air filter of burned popcorn smell
You would be better off to replace the filter. Purchase two and use the first one to capture the remaining smoke residue. Then install the other clean one to keep microwave free of smell. Check the web site www.partselect.com for the replacement filter. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Microwave Ovens
Wrong Grease Filter for Sharp R-1870 Microwave
I also have a Sharp over the Range Microwave oven that requires a charcoal filter. But my diagram shows that the charcoal filter goes behind the slotted panel at the top of the microwave. To reach the filter, you must remove a screw on the top edge of the microwave. This allows the panel to come off. Your charcoal filter goes there. Since your oven is new, you do not need to change this filter yet because it's not dirty. I would save it for future use.
According to my book, there are two kinds of filters with this oven. The charcoal filter is the one behind the front panel. The Grease filters ARE the two metal mesh ones. They can be cleaned with hot soapy water, or I put mine in the dishwasher.
Mar 14, 2009 | Sharp R-1480 Microwave Oven
When opening the door a venting sound immediately starts up.
The charcoal filter needs to be changed every 6-12 months, or sooner if it gets clogged.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts (including charcoal filters) by entering your full model number from the tag on the oven here.
Feb 11, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
141 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
