Are you having problem typing certain numbers on the keypad? Please state you questions a bit more detail.
Commonly, like yesterday, I fixed my niece's keypad by just cleaning.
The procedure is as follows: Power down your machine, unplug the keypad from the machine.
First blow the keypad with a hair dryer without the heat or a blower. This would remove the dust and.
Now take a medium size brush and brush those keys taking the keypad upside down. While doing this tap the backside of the keypad time to time.
The next thing is a bit scary. But if you do it right this is best. Spray some Windex on the keypad and use a tissue paper or a cleaning cloth and clean the keypad on and between the keys.
This solved my niece's keypad.
Hope this helps you too.
Clean all the dust from keypad, There must be no water inside the keypad. If you have dust or water issue then you must clean it up and retry keypad. If its still not working make sure the inside plug of keypad has not been removed. Do not try if you are not as much expert. Contact your nearby repairman to check it.
your set's keypad is need to be serviced. You have to open your cell phone and clean the inner contacts of keypad and the upper contacts of main board where keypad sit. clean with ear bud. dip the ear bud in perfume. if this not work then you need a new keypad for 6600.
Hi,it can be caused by Dirt on the keypads or the IC that controls the functioning of the keypad.
Clean up keypad by opening the phone, After cleaning, if still not functioning, you will need to replace keypad IC. Contact nearest skilled personnel on nokia phones to assist youin replacing IC.
if you know how to open laptop then remove keypad, clean it with cleaning solution. then re assemble. If problem exists change your keypad or approach hardware technician
the phone keypad is dirty, or the I C that control the keypad on the board of the phone is bad.
To check if the keypad is dirty, detach the front casing of the phone where the keypad is, clean with brush or a white cloth to clean of necessary dirt of the phone, then couple it back and test.
If after cleaning the keypad and is still not working, then the key pad I C on the phone board is damaged and it needs to be replaced.
Would advice if you to have the knowledge on how to open the phone, you can take it to a phone repairer to fix for you to prevent further damage on the phone.
does the keypad beep when you push the keys? if yes, the keypad is fine.
make sure that the keypad is plugged into the control board correct it. the control board is located behind the keypad
do you get any error messages? if yes, please tell me the #.
