Question about HP Color LaserJet 5500hdn Printer
Duplex printing Our agency has the HP 5500hdn. From one workstation, the worker is able to duplex print but from all other workstations, by checking in duplex (manual) and printing (as the first user does), the unit prints single-sided. What driver setting could the first user have that the others do not?
  • mkolar Feb 17, 2009
    Worked like a charm. Thank you!
    New Friend:
I want to print duplix with hp laser 4200tn
Posted on Mar 22, 2014
    Sergeant:
    Champion:
  • 274 Answers
On the workstation go into Control Panel, select Printers, highlight the proper printer, Right Click for secondary menu and choose Properties.
Select Device Settings tab, look under Installable Options, Click on Duplex Options field and select proper setting.
This may differ from printer makes and models.
Posted on Feb 17, 2009
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
Unable to find on network
is the printer connected through a network cable,if yes print a config page through the printer and check the ip/tcp settings from the printer and check it against the workstations
Jun 25, 2009 | HP Color LaserJet 2600n Printer
Labels not printing properly
El problema es que la impresora tiene diferentes parametros de impresion, de oscuridad o velocidad. Ajustalos para que sean iguales en el print server como en workstation. The problem is that the printer has different printing parameters, or speed or darkness. Adjust to be equal in the print server as workstation.
Jun 03, 2009 | Zebra Eltron TLP 2844 Thermal Label...
How to print both sides in this printer if we use windows 2007
Sorry to inform you , this machine does not support duplex operation You can try printing pages 1,3,5,7 etc then place back in printer upside down and print 2,4,6,8 etc Hope this helps you
May 01, 2009 | HP Color LaserJet 5500 Printer
HP DesignJet 1050c InkJet plotting issue
Friends,
You doesn't say what application and OS versions you have, or if the printer is shared from a server or connected locally to a workstation. This is signifcant to solve the problem. Please clarify.
To make this work properly, all machines should have the HPGL driver and all drivers should have both the "Autorotate" "Inked Area" boxes ticked - both under General > Printing Preferences > Advanced AND under Advanced > Printing Defaults > Advanced.
Then you should create a paper size that is as wide as the media is wide, and longer than the longest/widest paper size you're ever going to print (6-10 feet long is OK!) - BOTH under Printing Preferences AND under Printing Defaults. This will ensure that every "odd" paper size (within media width limits) is printed without problems.
If the printer is installed on a server and shared, these settings should be done on the server - and the driver should be reinstalled on the workstations. If not, these chanvges should be done on each workstation that has access to the printer over the network.
When using older versions of AutoCAD you might have to reinstall the printer there as well for the changes to take effect.
Note: This solution has worked successfully over several years while working at HP support. The suggestion about the looong paper size may sound strange but it works!
//Al
Feb 10, 2009 | HP DesignJet 1050c InkJet Printer
Cannot print double sided
tick box duplex option installed in driver, otherwise install correct driver with duplex option on server, and delete drivers on workstations.
Jan 04, 2008 | OKI C9300 Led Printer
Cant print from workstations
Try changing the driver for your HP LJP3005 on your XP machine. Use it with the HP LJ Series II driver.
Aug 10, 2007 | D-Link DP-301U (790069251979) Print Server
HP LJ4 not printing correctly
Is this printer conected directly to your workstation or via a network? If via network can the problem be replicated on another workstation? What drivers are you using for the printer and where did you get them?
Jul 17, 2007 | HP LaserJet 4 Printer
HP Color LaserJet 5500hdn Printer Logo
134 people viewed this question
Ben Johnson
