Question about Brother MFC-8220 Fax
Our Brother MFC-8220 keeps reading check cable.
We connected every cord that fits my computer with the fax,scanner, printing maching but it keeps reading check cable.
Please help!
  • Anonymous Mar 08, 2009
4 Suggested Answers
  • 787 Answers
SOURCE: How I clean Drum of Brother MFC 8220 Fax machine
If you mean drum reset
1. Open the front cover, and then press Clear/Back.
2. Press 1 to reset.
Posted on Oct 28, 2009
  • 159 Answers
SOURCE: I have a Brother MFC 8220 incoming fax problem
Here are a few possibilities:
Does it still say "FAX" on the display? If it says "TEL" it won't answer the phone. Changing it is just a matter of pressing the MODE button, which cycles through four settings. FAX is for dedicated fax lines. If you share the line with a phone, check your manual for info about the other two settings.
In your menu settings is a place where you can set the number of rings before answering. If it's set too high, the sending machine will give up while your machine is still waiting for that 9th ring. I know you wrote that nobody's messed with it, but it's worth checking.
A glitch in the memory may be disabling reception. We can reset it in the Maintenance Mode:
From the Ready state, press these buttons in rapid succession:
* [the star on the phone dial]
If you did all that in under 2 seconds, the display will show MAINTENANCE. If you were too slow, you'll just be in the menus somewhere. Press Stop and try it again. You have to ignore all the error beeps while you do this; it's designed to be nearly impossible to do accidentally.
Once you have MAINTENANCE on the display, simply touch 91 and wait. The machine will clear all its memory, except your stored phone numbers. In a few seconds it will return to MAINTENANCE. Press 99 to exit the mode. The machine will go through it's entire start-up, as if you'd just plugged it in.
You don't need to use another fax for initial testing. Call it from another phone - even a cellphone - and see if it answers. If it squeals horribly in your ear, you've probably fixed it. Now try faxing to it.
If that function 91 didn't help, try something harsher. Go through the same routine above to enter Maintenance Mode, then, instead of touching 91, touch 01. That will clear all memory to the sate where it was when you first unboxed it.
If nothing above helps, it almost certainly needs a new Main Board. Replacing that on a non-warranty machine may not be worth it, but use Brother's website to find your nearest servicer and find out.
Posted on Jan 27, 2010
  • 1218 Answers
SOURCE: Brothers fax MFC-8220
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock.
Posted on Sep 22, 2010
LED READS Gibberish on Brother MFC 8220
Try changing your local language on the maching to English. ;-)
Mar 21, 2010 | Brother MFC 8220 All-In-One Laser Printer
I am tryn to download software to install brother mfc 8220 fax printer copier scanner pc fax machine. and having trouble getting right software and loaction for it. using windows xp
Assuming you're in the USA, go to's download page. Select the Multi-function family, then your specific model in the box that appears, then your operating system. Agree to the software license, and you'll get a page of drivers & stuff. If you have a fast Internet connection, go for the complete package.
There may also be a program to uninstall the drivers. If you've been trying to connect & use the machine, start by unplugging it from the computer and run that uninstall program. Windows often tries to install an almost-good-enough driver, and the real Brother drivers don't play with that.
Then run the setup program for the driver package you downloaded. It will tell you when it's time to plug in the printer. A computer reboot may be required when it's done. The installation program will tell you.
Jan 22, 2010 | Brother MFC-8220 Fax
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
Copies are entirely black, when printing from computer, works fine
I believe you have a bad scanner block, probably cost as much to fix as buying a new one
Oct 25, 2009 | Brother MFC-8220 Fax
3 black smudge horizontal lines on prints
Your brother can send faxes without printing the pages try your computer just you should download the driver.
You can download the driver from this link: " ".
About the lines which appear on the print, you will have to buy a Drum unit for your Brother 575, because the drum cleaning blade has quit working and there is no other way to fix this only by putting a new drum unit.
the drum unit is different from the toner cartridge, but if you search good you can find them together for lower price.
Please rate me
Jul 15, 2009 | Brother MFC-8220 Fax
Brother MFC 8220 Error code 71
that code indicates that your laser unit has gone bad. no way to reset or repair without a tech replacing the laser unit itself.
Mar 18, 2009 | Brother MFC-8220 Fax
I Have a Brother 8220 without any cords except power cord
1.Power cord for electricity
2.Handset curled cord
3.Telephone line cord
Yes there is, go to Brother Solutions Center.You can download manuals, brochures etc.
Feb 18, 2009 | Brother MFC-8220 Fax
The Black line on the paper when I scan and fax
try cleaning the grid on the drum unit and you might replace the drum
Dec 22, 2008 | Brother MFC-8220 Fax
Its the CIS unit. Part number LE7949001. $70 retail price.
Aug 15, 2008 | Brother MFC-8220 Fax
Brother MFC-8220 Fax Logo
350 people viewed this question
James Cagle
James Cagle
Jim Keysor
