Question about Mitsubishi WD-52525 52" Rear Projection HDTV
The remote operates all the units except for the TV's vol, channe
The Mitsubishi uses a NetCommand 2.0 (6 years old now) The remote has a slider at its top which can work other accessories. All other accessories work using the TV's remote except the TV now! No channels, volumn, or menu will work? Interesting, how one morning its working and the next day it's not. I have reset the remote and the TV in hopes of re-establishing a IEEE connection or something. Has anyone had to deal with such a problem?
    Novelist:
  • 184 Answers
There are 2 possibilities: either you have a stuck front panel button, or the remote sensor is bad.
You can eliminate the button issue by removing the front speaker grill and access panel and disconnecting the button assy wiring harness.
There is a plug/socket connection there that you can easily disconnect. If after disconnecting the control panel, you still have no remote, its the sensor. Its located behind the screen assy mounted behind the CRTs. You will have to remove the screen assy to get to this.
If you're not up for this, a service company will charge you $300 or so to replace the sensor for you.
michtech
Posted on Feb 17, 2009
Why wont my humax connect to my Dennon amp via the hdmi my old foxstat one does
This might be due to having one of the following enabled on the Denon:
AOC - E-Link
Hitachi - HDMI-CEC
LG - SimpLink
Onkyo - RIHD (Remote Interactive over HDMI)
Panasonic - Viera Link
Philips - EasyLink
Pioneer - Kuro Link
Samsung - Anynet+
Sharp - Aquos Link
Sony - Bravia Link & Bravia
Toshiba - CE-Link & Regza Link
Mitsubishi - NetCommand
Oct 13, 2015 | Humax Televison & Video
I transfered from watching my sattelite tv to watching a dvd using the tv control. The dvd sound worked ok, but I couldn't get a pictue. Then I tried to watch tv again, but the vidio would not come in,...
Just in case, here's the 108-page user's manual for your TV:
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
Yor "NetCommand" TV remote is a wondrous thing, capable of throwing off anyone.
When the 'Device Selection Menu" is dispayed, and only when the device icon is highlighted,
does the key work, and it also only works when the remote is in "A/V Receiver" mode -
not in "CABLE or DBS" mode, nor "VCR" mode, nor "DVD" mode.
So, (1) set the NetCommand remote to "A/V Receiver" mode
(2) bring up the Device Selection Menu, using the key on the remote
(3) highlight the Satellite receiver input icon (highlighted with a Yellow outline)
(4) press GUIDE on the remote, to swap the analog digital setting.
Also displays ChannelView for Antenna 1 and Antenna 2 - you may have accidentally
set the TV to get its input from the wrong Antenna.
If your TV has lost memory of its DBS source, you may have to re-teach the TV (using the remote)
that the DBS (Digital Broadcast Satellite) input exists, and to which input its connected.
Refer to "Edit NetCommand, Add an A/V Receiver", pages 39-45 of your Owner's Manual.
Jan 31, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Same problem on 18 month old Mitsubishi
As an experiment..plug the tv out of the wall. Wait. plug it back in. Does the green light stop blinking? If so, then the TV needs to go through setup/netcommand again. If not, the problem may not be an easy fix.
Jul 08, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
The 52525 is definitely going to either:
1. have the caps on the FMT/DM board replaced (not something I'd recommend you do yourself)
2. have the electrical chassis rebuilt (as sometimes, you can replace the caps and still have the problem).
wait time: 4-8 weeks
cost to rebuild: $400-$500
cost for labor: $200-$400
Oct 13, 2008 | Mitsubishi WD-52627 52" Television
Cannot change my Mitsubishi WS-55615 to switch from 480 to 1080I
You cannot change the setting on the TV itself. you need to go through the settings on the equiptment you have plugged into the TV to change their settings to display a different resolution.
Sep 15, 2008 | Mitsubishi WS-65413 65" Rear Projection...
No video in any of the TV inputs
first try resetting and rebooting. reset = menu, 2470, enter.
reset is press reset button and wait for green lite to stop blinking.
if that takes care of it great. if not it sounds like a signal board or dm problem and will need repair. check out www.tv-techs.com
Sep 06, 2008 | Mitsubishi WD62628 62" Projection HDTV
Can't learn remote buttons in NetCommand
kinda sounds like you are putting the first steps in right like the remote is excepting the command but the last step try to hit enter or something sound like it is excepting code but the last step deleteing okay shad
Apr 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
NetCommand remote control
make it sure you're on the right atenne, if not you can use both...
Oct 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
