Question about Olevia LT32HVM 32 in. LCD Television
Sound Noise Using HDMI Cable
When I use a Sony or Toshiba up-convert DVD recorder/player with my 32-inch Olevia LCD tv, I get sound noise from the HDMI cable. To fix the problem, I use the remote on the recorders to go from 480P to 720P to 1080I and no more noise.
Is there another fix for this?
In addition, I have tried several brands of HDMI cable.
The Olevia tv is two years old.
The first solution was to use the remote controls on the recorders and shuttle from 480p to 720p to 1080i.
The other solution was to run left and right audio cables from the output of the DVD recorder to the audio inputs of the tv. Then, go into the setup menu of the recorder and tell it not to output sound using the HDMI cable.
The first solution has to be done each time the machines are turned on for the first times of a day.
The second solution fixes the problem once and for all....
Posted on Feb 18, 2009
Sound comes and goes constantly on a sony tv model KP60XBR800
About 27,600,000 results (1.16 seconds) Search Results
    Sony TV sound issues - Forums - CNET
    www.cnet.com > Forums > Sony
    CNETJun 11, 2015 - I have a Sony Bravia KDL52V5100 LCD TV & after only having since May 2009, I am now having sound ... I'm going to purchase a new HDMI cable to see if that might solve the sound cutting out problem. ... Has anybody come across problems like these 2? .... Sony is and always has been one of the best TV's on the market. Netflix app on Samsung Smart TV audio dropping out
    Jun 11, 2015
    sony bravia automatically turning off and on
    Jul 7, 2012
    Clicking noise after powering off sony kdl-40v3000 lcd hdtv ...
    Oct 25, 2007
    More results from www.cnet.com
    A loud humming or buzzing noise is coming from ... - SONY
Jan 05, 2016 | Sony Televison & Video
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
How to hook updvd player to tv set
if the dvd player has hdmi connection use that.
if the TV has hdmi input use that.
if you can do both of these then use the TV remote to switch input to hdmi when the dvd player is on.
as an extra you can use toslink optical or coaxial digital cable from TV to home theater receiver for surround sound.
Jan 02, 2010 | Olevia LT37HVS 37 in. LCD HDTV
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
No sound
If the tv does not have sound with out connecting the dvd then you are having a problem in your audio circuit have a tech look at it.if its only when you connect the dvd then you could have connect cables wrong.you cannot route a dvd through a cable box.any dvd s compatible with tv so long as the connections are there. goodluck.
Dec 28, 2006 | Toshiba 32HF73 32" TV
SHARP,PIERCING, ALARM LIKE NOISE COMING FROM TV
unhhok all the sources from the tv as to eliminate where it might be coming from, hook up one source at a time you might find the problem that way
Oct 20, 2006 | Olevia LT32HVM 32 in. LCD Television
Olevia LT32HVM 32 in. LCD Television Logo
669 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
