Question about Indesit W 123 Front Load Washer
Hot/cold feed indesit wg1130t do you have to have a cold and hot feed or can you just have one
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
You can have just cold but you will need to have both hoses, (presuming it's hot and cold fed washer), connected to the water otherwise the machine will be waiting for the water to flow that isn't there. you can buy 'y-shaped' adaptors for this purpose.
the water is heated inside the machine to correct temp anyway.
Posted on Feb 17, 2009
Can i install mach with hot and cold feed to cold feed only and how can i do it
I suggest you check with your local white appliance engineer but I don't think you will have any difficulty sourcing the parts you need from your local plumber's merchant, motor factor, hydraulic specialist or motor accessory shop, depending which way you want to do the job.
You could, for instance, make a small two-port manifold from standard tap connectors, elbows and copper water pipe if you want the result to be workman-like and substantial or alternatively fit a tee or "Y" junction into your cold water hose and then shorten a hot water hose and connect to the unused branch of the tee.
It will need to be a neat and secure job especially if your cold water pressure is high; in order to avoid floods.
The tee or Y should be brass or nylon to prevent corrosion and preferably have a barbed surface and good well-fitting clips should be used to secure the hoses.
Good quality plastic fittings are difficult to source and brass fittings equally so. I suggest having a look around locally and take a cut hose with you to show the guys what sort of size you are seeking.
You might eventually decide to make the manifold which will be a satisfactory and permanent solution. A pressure reducer might be needed in the "hot" water supply and a standard type would fit into the 15mm copper pipe.
Feb 12, 2015 | Indesit Washing Machines
Hose attached to cold tap will water still heat up
The washing machine does not heat the water, you must pre-heat it and feed it by the hot water inlet.
May 30, 2014 | Indesit W 83
In a previous house, we had both a hot water feed and a cold water feed. My new house only has cold water feed, can i still use this washing machine?
In a word- YES!
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end screws into the cold water supply and the hot and cold washer pipes screw into the double end. The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
Good luck,
John C
Mar 16, 2011 | Indesit W 123 Front Load Washer
What are the official dimensions of an indesit wg1130t
These are the official manufacturer specified dimensions for the WG1130T
width 59.5cm / 595mm / 23.42 inches
height cm 85cm / 850mm / 33.46 inches
depth (front to wall) 55cm / 550mm / 21.65 inches
If you need any further specicications, please post back or download the full user manual from here:
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WG1030G_WG1130TG_WG1230G_19502233000.pdf
Regards,
BElectric
Nov 28, 2010 | Indesit W 123 Front Load Washer
Indesit 1200 washing machine boils everything and
make sure you have connected the cold water feed and not a hot water supply, these machines need a cold water feed only
Jun 03, 2010 | Washing Machines
Indesit Wg1130T
DRAIN PUMP BLOCKED OR FAULTY
Oct 25, 2008 | Indesit W 123 Front Load Washer
Indesit DIF04 integrated dishwasher
Dishwashers normally are hot or cold feed.
My wife runs water at the sink to get it hot going in before turning on the dishwasher.
You can use either cold or hot water.
We have ours hooked up to the hot water side.
They work better hooked up to the hot water.
Mar 21, 2008 | Dishwashers
WIL113 Indesit 1100
yes you can run it with just a cold feed, not sure whether this model has two water inlets on the back or just one, but if there are two then you will need to get a y splitter (cost about £1) ebay or a good plumbing shop will sell them.
4a7a980.jpg any quires feel free to ask.
Feb 20, 2008 | Indesit WA 125 Front Load Washer
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Washing machine
HOT WATER VALVE IS FAULTY
Nov 29, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
142 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
