Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Surfboard Cablemodem not communicating with Belkin Wireless Routr
Ok Simple setup here. One ethernet cable from the cable modem to the WAN port on the belkin wireless router. The Belkin Wireless Router has 4 additional ports, which I connect another ethernet cable to it. That line goes to a 10/100mbp 8 port HUB wich of course brances out to the system systems on my net work. This is the way you are suppose to do it. takes less than what 5 to 10 minutes. Comcast modem has no settings you can configure, it has a MAC address stored in the memory. The Wireless router will not talk with the modem or vice versa. This 6 hour job has gotten me nowhere. I need to get the Cable modem to talk to the router which will spit out DHCP addresses. Issue is the Cable modem acts as a DHCP server too. Even when I turn DHCP off on the router's side, nothing.
  • 12 more comments
  • kstimac Feb 17, 2009
    comcast is spitting out DHCP addy's like 192.168.100.10
    Would I need to create a static IP address using simular numbers. Cause I tried commecting the cable modem to Port#2 on the wireless router after turning off DHCP on the router. Nothing.
    I will try that. Thanks..
    Another thing came to mind. If the comcast modem has a Static IP, and the modem is acting like a DHCP server. Would I need to enter in the Static IP from comcast into the router??
    I tried that. Without using a router just a straight 8 port 10/100 hub I received 169.address. nothing anywhere near 192.168. here's the kicker..IF, I disconnect the other PC's lan cables from the hub, my PC will have internet. Once I start connecting more PC's I loose the connection. Thats why I firmly believe Comcast has my main PC's mac addy stored and I can't add anymore PC's to the connection...
    Thats what I thought at first...I checked the settings ( well the ones I can look at ) there are no means and ways for me to change setting on my Surfboard Modem. But ih the Connection settings it states DHCP = on
    192.168.100.1 is the IP to get in...The only options I can actually use is Reset the Modem and reset modem to Factory settings.
    No other options or settings I can mess with, its like pre-set, no changes can be made...
    This is what I found out from a forum on the net...Seems to be Accurate.
    "Comcast has a little known "trick" that they use when setting up users. Here's how it works:
    When Comcast first comes to setup your new cable modem service, they insist on connecting it to your computer and "testing" it. Most people think nothing of it, and that it's good customer service ...truth be told, what they are doing is attaching your computer's MAC address to that cable modem, so that you cannot create a wireless network. This is because they want you to pay them $150 to do this for you."
    Sound bout right??
    "Ghost the MAC address within the router?"
    I think I would need a modem that I can adjust settings...
    Belkin Wireless G F5D7230-4
    I hope so...I have a Recording Studio to run..We have a band coming in that wants to do a live POD cast. I had DSL and it lagged, choppy video. Figured Comcast with 20mbps would be the best option. Course that hasn't been the case yet..
    This is me BTW
    www.myspace.com/gavincountry
    I also work as an
    Micro Computer / Network Tech II
    DCSE, MCP, and A
    For a publishing house Down town Nashville
    Been there, printed the manual
  • kstimac Apr 09, 2009
    Trashed the Wireless Belkin and got a Linksys 4 port/ DSL/CABLE Router "WIRED"
Find out what the subnet of the current router you want to connect the wireless router to. your isp router probably has 192.168.1.1 something similar, which will give out ip addresses of 192.168.1.100-192.168.1.254, change the belkin routers internal ip address to 192.168.2.1 and turn off dchp server, that should solve your problems, save settings, power down belkin router then power back on.
Posted on Mar 02, 2009
  • pslice669 Mar 02, 2009
    Also, do not plug ethernet cable into the wan of the belkin router, what you want is an access point now, since you already have a router which is handing out dchp addresses. plug the ethernet cable from an open port on the isp router and plug the other end into port 1 on the belkin router.
    Sergeant:
    Champion:
  • 274 Answers
If the modem is actually passing out DHCP, then you have to connect the modem to the router 4 port lan side and not the wan port. Give the router a static ip like 192.168.1.2 and you can talk to it and configure the wireless features.
Posted on Feb 17, 2009
  • 14 more comments
  • Ricky Ostrom
    Ricky Ostrom Feb 17, 2009
    If it is actually passing out addresses in the 192.168.100.xxx range, then set the router as I explained with an address like 192.168.100.2 and the router will function like an access point. If the modem is not passing out addresses, but there is an address conflict in the range 192.168.xxx.xxx then set the router to 10.10.0.1 and pass out dhcp in the range of 10.10.0.xxx with submask 255.255.0.0
  • Ricky Ostrom
    Router will pickup the modem ip automatically. If the modem is handling dhcp then without the router, the modem can connect to the hub/switch and bring all the computers online. You can try this and see what addresses get assigned to each computer via IPCONFIG /ALL
  • Ricky Ostrom
    I have Comcast and my modem does not handle DHCP.
  • Ricky Ostrom
    What make is the router?
  • Ricky Ostrom
    Ok, put the modem back on the router wan side and UNPLUG power for 15 minutes. Turn on router DHCP. Set router to Auto Configuration DHCP. Set local ip address to 192.168.1.1 and 255.255.255.0 Enable DHCP Server and start ip addresses at 192.168.1.100 with about 50 users. Do not set DNS, since it will be automatically passed. more to come
  • Ricky Ostrom
    According to Motorola's documentation, the modem can handle up to 52 ip addresses, but they have to be purchased. So the router is needed. You should be able to program the modem thru the browser with it's ip address.
  • Ricky Ostrom
    Typo correction 32, not 52.
  • Ricky Ostrom
    With the modem connected to the router thru wan. Within the router console under Status can you see the modem settings (i.e. Domain, DNS, IP)
  • Ricky Ostrom
    They check the MAC address for security. Normally, if you disconnect the power on the modem for about 15 minutes and reconnect, it will be rescanned and the MAC address will reset. If not, you can call them to reset the modem. Otherwise, if you know which computer the modem was originally on, you can ghost the MAC address within the router.
  • Ricky Ostrom
    Also known as cloning the MAC address.
  • Ricky Ostrom
    WHAT MAKE IS THE ROUTER???
  • Ricky Ostrom
    You can get this going. It's either an ip conflict, MAC security, or DNS issue.
  • Ricky Ostrom
    Go back to the basics. Connect the computer to the modem and confirm connection. Write down MAC Address of computer via IPCONFIG /ALL . Connect modem to wan of router and computer to router. Set router as previously mentioned: "Turn on router DHCP. Set router to Auto Configuration DHCP. Set local
    start ip addresses at 192.168.1.100 with about 50 users." In router Clone MAC Address you wrote down. Check PC to see if it picked up new ip from router and check router status to see if it picked up ip from modem.
  • Ricky Ostrom
    You have probably been here already, but here is the support sight for that rotuer. http://www.belkin.com/support/product/?l...
    It's suggested to update the firmware.
  • Ricky Ostrom
    The Belkin router is suggesting you set the ip for 192.168.2.1 and pass out 192.168.2.xxx
  • Ricky Ostrom
    I have to go for now. I'll check back on progress.
How do i connect belkin n300 wireless router to motorola surfboard SB5101 cable modem?
The ISP modem (cable) connects to wireless (yellow port) PC and other devices connect to any port available on wireless. This is the standard setup.
Aug 28, 2012 | Belkin Share N300 Wireless N Router
Haw can i install Belkin wireless router N300 without the CD
You can easily follow the following steps to install it without a setup CD
Step 1: Please find a compatible power source and plug your modem into it.
Step 2: Now, you can connect your computer to the modem using an Ethernet cable without the router being installed.
Step 3: please verify whether your computer is receiving an internet connection or not. Just click and access any website of your choice.
For more details kindly visit How to Login Netgear Wireless Router Routerlogin net
Apr 10, 2012 | Belkin F5D7234-4 Router
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
Security
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jul 23, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I cant connect to the internet
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Jun 10, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Cable to ethernet cable my existing modem has a cable on inlet & my new modem has an ethernet cable on inlet
A router is not a modem.
Your existing modem is a modem. It better have a coaxial cable inlet and an Ethernet cable outlet. The wireless router ought to have 5 ethernet ports, 1 WAN and 4 LAN.
Follow the setup as outlined here http://en-us-support.belkin.com/app/answers/detail/a_id/470/p/395
Carl
Nov 07, 2009 | Belkin (F5D7231-4) Wireless Router
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
914 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
