Question about Maytag SkyBox MBV1976A Beverage Dispenser
When i turn the box on all it does is click.
Could that be the compressor or the relay switch. are either one of them available to buy. please reply as soon as possible. i love the box, but it will not cool.
  • Anonymous Feb 18, 2009
    I have the same problem that the compressor does not run and it does not cool.
    Where do yo get the relay parts?
    Fred
    Problem Solver:
  • 4 Answers
I had the same problem and maytag was no help.. someone from FIXIT.com emailed me with the solution so I will do the same.. buy part # 4387835 relay switch from Whirlpool (about $23.00) You can open the back unplud the old switch and replace the wires, it is simple. the top wire that is unpluged I did not replace., I plugged that back in and it worked.. I have good beer again
Good Luck
Louie
Posted on Mar 10, 2009
Evaporator fan running,condensor fan running,compressor not running.
HI. This will essentially be the result of a failed compressor start relay, or the compressor itself may be damaged, as well. I will lay out a procedure that will help diagnosis the situation. Please reply with the correct model number and brand for accurate part numbers, if possible.
Procedure:
THE RELAY
The compressor relay starts the compressor. A fault relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator. The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. On soem units. the relat may not be covered at all.(each modle may vary). Benethe the terminal cover(if equipped), you will find the compressor relay, and the overload protector as well. The electrical terminals of the commpressor motor are loctaed here also. Remove the compressor relay by pulling it straight off from the compressor, gently. Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing. Test the relay with a ohm(multimeter), for continuity. Set the meter to the ohms setting X1. With the relay upside down, place the probes into the terminals labeled "S" and "M"(the labeling may vary on each modle). The meter should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up). With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The meter should now display an ohm reading of infinity (or the tester should not light up). Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L". The meter should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity. With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M". The meter should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms. Now, if the relay fails these described tests, it shohdl be replaced asap.
COMPRESSOR TEST PROCEDURE
The compressor is accessed from the lower rear of the refrigerator. Generally the same proxsimity of the realy. The compressor motor can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. The main testing points will be the actual terminal post that hold the relay, gently pull the relay of the terminal box on the side of the compressor, and use the relay holding probes for testing. Once the relay is removed, Place one probe on any terminal and then touch the other probe to each of the other two terminals. The multimeter should display a reading of zero ohms. Be sure to set your meter to 1X before begining. Now move the first probe to a different terminal and test the other two terminals with the other probe. Finally, move the first probe to the last terminal and test each of the other terminals with the other probe. Every test should have continuity with the multitester displaying zero ohms. If the compressor motor does not pass all of these tests, the compressor will require professional service. Now test the compressor for ground. With the multimeter still set to X1, touch one probe to bare metal on the compressor housing (it may be necessary to scratch away a little paint to expose the metal). Touch the other probe to each of the three terminals in turn. None of the terminals should have continuity; the multitester should display a reading of infinity. If any of the grounding tests show continuity, the compressor will require professional service.
Oct 05, 2011 | Samsung Refrigerators
How to turn off air compressor on 1999 ford expedition
  • Under the hood in the relay panel will be a relay for the compressor. When you locate the relay box look on the underside of the lid for the legend (layout) of the relays. Pulling that relay will stop the compressor from turning on.
  • You can also just unhook the connector on the compressor and secure it to stop the compressor from turning on.
  • If you need the compressor clutch to not turn at all, like if the bearings are bad, then you need to buy a smaller belt to bypass the compressor all together.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 19, 2011 | 1999 Ford Expedition
I have a ge profile refrigerator there is no power going into the relay compressor. The four thermistors are good. Where or what should I check with a voltohm meter on the control board or temperature...
You should firstly test your fridge DOOR switches with your multimeter (simply test for open/closed continuity), as these switches signal the compressor relay. Some fridges usually have a time delay after switch is activated also. If these switches test ok, then all I can suggest is changing out the control board.
May 13, 2011 | Refrigerators
It won't start no click sound if I turn the temperature control to maximum
If your hearing a clicking sound and it won't start your looking at either the relay switch for your compressor or the compressor itself. I recommand replacing the relay switch first to see if that solves your problem. Just look for the model number of your freezer, visit your local part store (reliable, amre) and ask them for the relay switch for the compressor. It should be under 20 bucks or so.
To install the part you first need to located the compressor. There should be an opening to the freezer somewhere in the bottom. Once you find the opening (after removing the cover) you should see a large cylinder metal container, this is your compressor. If the freezer unplugged located a small box attached to the compressor that looks similar to the relay you purchased from the part store. Remove the wiring for the old relay and then proceed to remove the relay (it should just be plugged in). Once it is removed place in the new relay. Plug back the fridge and see if your freezer works. If the problem persists it will be your compressor. You should have a professional have this replaced as it requires weilding and removal of the freon gas. The repair for a compressor job is $500 up.
I hope this helps and good luck. Please give positive feedback if this helps :)
James Memije
Head Technician
Accufix Appliance Service Centre
www.accufixappliance.com
Nov 20, 2010 | Danby 5.5 cu. ft. / 156 liter Chest...
My 93 plymouth voyager won't start unless I spray starting fluid down air cleaner, then it only runs a few seconds.
Listen for fuel pump when turning ignition to on position. If no pump sound, locate fuel pump fuse and relay in box under hood. First check fuse, then listen to relay while ignition is turned to on. Relay should click. If no click, replace relay. If click, circuits are good and pump is likely bad. Please reply if you have questions.
Sep 09, 2010 | 1993 Plymouth Grand Voyager
We have bought a new relay switch which we were told was the problem how do you install
Most compressor have common on the top prong, but some common is down like in photo. When you get a chance to send me your Sears Kenmore model number I can help you better. Click here to see what some do with Whirlpool compressors. It is really simple once the power is disconnected. It must be correct so please send me the model number or a small photo of the compressor as in the view in this link=> How to Replace a Whirlpool Relay I will return in a couple hours from a service call. If you reply I will see that you replied. You may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 20, 2010 | Kenmore Refrigerators
Skybox by maytag quit cooling
lhdmd1...I have a similiar problem and have just started looking for a fix. If I find a solution I'll send you a message.....if you find a fix I would appreciate could you please share.
Jul 07, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Compressor is not working on it tries to click but could not start
You should be able to pry relay cover off with flat screwdriver. Make sure you unplug unit first. Relay and overload can be replaced. If that doesn't fix it, then compressor is most likely bad
Sep 13, 2017 | Refrigerators
Whirlpool gold side by side refrigerator relay compressor?
turn it off for an hour or so and give the coils time to thaw just in case they somehow froze up. also if the frig was tilted in the wrong direction (which it doesnt sound like it was since it has food in it!!!) it could need time to let the refrigerant and oil settle back into the compressor.
where are you located (cold or warm climate)?
and where is the frig located (in your home)?
Jan 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag SkyBox MBV1976A Beverage Dispenser Logo
126 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
