Question about Zanussi IZ12 Front Load Washer
Engry problem hi can i put a hot water feed on to my machine.theres only one blue hose on it,point being im using and waisting power to heat the water to temp ,make is zanussi iz12
  • derekbracken Feb 17, 2009
    ok ,but can i apply hot water and disconnect the heating elements without doing harm ,and i can live with the above u mentioned,(electrician by trade) just trying to reduce power bill,bad times ,i put a crip meter on the supply and the machine was pulling 6amps or there abouts ,thanks
    ok,no i dont have free hot water ,but was considering putting in a solar panel ,and i also would have hot water available all the time from my oil heating,Thanks rob
  • 134 Answers
HI
Its true you are using power to heat the water....
BUT
all the time its heating through different temperatures, different stains are removed. Also its agitating for all this time. If you put hot water in only it wont wash as long. Also the incoming temperature could be too hot for some fabrics. Also you wil be using your hot water to do all the rinses.
Its up to you, but, zanussi know what they are doing
Posted on Feb 17, 2009
  • royzee Feb 17, 2009
    HI
    you wont do any harm by putting hot in instead of cold, as long as its not so hot as to ruin delicate fabrics.
    I wouldnt disconect the heater tho.
    If the temp of the incoming water is not high enough for the programme selected, the machine will switch on the heater. If youve disconected it, the machine will just sit there. The programme wont advance untill the thermostat closes.
    Do you get free hot water....lol
    Rob
I have a Maytag front loading washing. I put the dial on cold water, but it shoots out hot, and yes the hoses are connected right then if u put it on hot it starts out cold but then it's rinses hot .
Certainly sounds like the hoses are reversed. There are usually two hoses, one blue and one red. Sometimes they are just grey. On the bottom of the washing machine are two hose connectors. One should be blue and one red. Check that the red hose hasn't been connected to the blue (cold) male connector. Then make sure those are correctly fitted to the hot and cold supply.
Aug 24, 2015 | Washing Machines
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
Does the wma76 hotpoint need a hot water feed? Is a cold water feed enough?
Hi from retired Englishman in France (it's 21:29!),
If your washer has 2 pipes for feeding water then one is for hot and the other is for cold naturally.
All washing machines have a water heating element in them- in case any hot water supply is not hot enough for its wash.
If you only have a cold tap you will need to purchase a 'Y' connector. This screws onto the cold tap supply (single end) and the hot and cold feed pipes connected to the washer screw onto the other two ends. The machine will now be fooled into thinking it has two separate feeds!
The machine opens the valve for the 'hot' water supply (which of course is cold) and the heats it up to the required temperature for the wash cycle. Afterwards, when the machine requires cold water for rinsing, it opens up the 'cold' supply (which is the same supply as for the hot water!) and is happy.
Hope this answers your question.
John C
Jan 26, 2011 | Hotpoint WMA76 Front Load Washer
Im instaling a 2 yr old zanussi aqua 1000,it has a hot and cold feed,there is just a cold feed at the house
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=213690&brand=&model=&part=y-piece&style=washerhelp
Washing machine is a hot and cold fill, but I only have a cold water supply You can use a Y Piece connector (external link 4Washerhelp spares) to connect the hot and cold fill hoses to a single cold water supply. The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may be able to buy this part also from a DIY store like B&Q)
Oct 21, 2009 | Washing Machines
Washing machine doesnt seem to be heating up the water
Hi. Washing machines are dependent on the water supply for their heat. If it isn't getting hot, it's from lack of hot water. Put the machine on a setting requiring only hot water for the initial fill, and start the machine. If the water is at a low or no flow rate, proceed as follows: Unplug the washer, close and disconnect the hose from the hot water faucet. Inspect the inside of the hot water hose; there is usually a screen in the end to catch scale and sediment. If you see anything there, remove the washer and screen, and clean it. Reinstall the hose, and disconnect the hose at the washer end of the hot water hose. Open the faucet, and discharge some water into a bucket. If there is no water, you may have a plumbing issue, so I'd back up to the faucet and check. If you do have water there, inspect the solenoid valve inlet (where the hose connected) for another screen. Clean as before. If debris was found at either location in a sufficient quantity to obstruct your water flow, reconnect the hose, and try to get hot water into the machine again. If no hot water will enter the machine, the issue is probably with the solenoid valve. If you have an electrical test meter, you can test the valve, or replace it. Any appliance parts supply house will have your part.
Best regards, and good luck. --W/D-- Please feel free to rate this solution, and let me know what you find out.
Jul 26, 2009 | Washing Machines
Washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Mar 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hot/cold feed
you can have just cold but you will need to have both hoses, (presuming it's hot and cold fed washer), connected to the water otherwise the machine will be waiting for the water to flow that isn't there. you can buy 'y-shaped' adaptors for this purpose.
the water is heated inside the machine to correct temp anyway.
Feb 17, 2009 | Indesit W 123 Front Load Washer
Hotpoint Aquarius WF100
Firstly, there should be only one hose, always connected to the cold supply.
The unit will heat the water to the setting you choose for the wash (40 - 60 - etc)
Secondly, if the unit is leaking water, try turning down the cold pressure, this will slow the supply pressure to the unit and prevent spray out from the detergent drawer.
Your supply tap should have an isloting tap on it, adjust this until it sullpies water at an acceptable rate.
Do this by feeding the hose into a bucket/basin and tweak it until it pours out - not sprays out.
This should alleviate any leaks around the machine.
Hope this helps.
Oct 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Gushing water - Hoover SPB11 washing machine
First plug off the wall. Before connecting the "hoses" (both hot and cold) to the machine inlets see that the inlet is clean. Connect the outlet hose to the standpipe, not too deep. The outlet hose has to be about 3 feet above ground level; there is a water level mark behind the machine. Both the inlets should be well screwed in, noting the threads of the inlets
You said the water was gushing.....into the machine? Fine .....what next.......post back.
Dec 06, 2007 | Washing Machines
Zanussi IZ12 Front Load Washer Logo
100 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
