Question about Teledyne Laars Pool & Spa
Series 2 esc 325p won't get above 85 degrees on full throttle
Burner seems to have a blue flame and seems to run fine but our pool hot tub is now the warm tub
    Top Expert:
  • Teledyne Laars Master
  • 7,161 Answers
If using a aqualink and hooked into pins 1 and 2 on long plug turn heater all the way up and let the aqua link control heat
Posted on Jan 14, 2016
  • 208 Answers
SOURCE: hercules250 pool heater lights but not heating up the water hot
take it to a pool service center and get it inspected
Posted on Jun 22, 2009
  • 246 Answers
SOURCE: it heats the pool but the hot tub gets warm for
ARE THE TEMPETURE SET HIGH IF YES THEN THE FLOW VALVE IS BAD . WHAT ABOT THE FLOW TO THE SPA CHECK THE PRESSURE READING WHEN SWITCH FROM POOL TO SPA IF VERY HIGHT THE JETS MAY BE PLUG MAKING THE FLOW TO SLOW FOR THE HEATER TO WORK OK
Posted on Dec 07, 2009
  • 990 Answers
SOURCE: My heater ignites and blows really hot exhaust
The water is mixed on the back side of the heater and will exit the heater at 7-11 degres hotter than it came in. This will keep people from being scalded at pool side. So what you have sounds normal.
Posted on Apr 18, 2010
  • 64 Answers
SOURCE: Not heating the pool water
The burners could be sooted, the burner orifices could be dirty or clogged. It would be similiar to an engine not running on all pistons. The power element could be bad and or stuck. Lastly, the gas pressure could need to be adjusted or is out of adjustment. Some of these are items you could might be able to diy depending on your handiness. Some require special tools. HTH
Posted on May 19, 2010
  • 990 Answers
SOURCE: Hot tub heats from 85 to 98, then E05 message. Max
Could be the temp sensor about 50-60 bucks, the book will say the board about 350-500 bucks. Try the temp sensor first. If it's reading over what the water is then that is probally the problem.
Posted on Jun 27, 2010
My Pentair Mastertemp 400 temperature is reading 20 degrees too low. I've replaced the thermistor already. Any ideas?
bummer hi limit wont do that but tep sensor will or control board also make sure water is flowing freely,
you will want to check the manifold bypass and thermal regulator
May 29, 2014 | Pentair Mastertemp Heater
I have a Jandy XL 250 the exchanger was sooted up the burners were disfigured from overheating so ive cleaned the heat exchanger replaced the burners and the front panel still gets very hot after about 20...
flame should be blue, this sounds like a natural gas unit (orfice) running on LP. Lp is burns hotter than nat. and will burn orange. and use huge amounts of fuel.
Aug 10, 2013 | Hayward 250kbtu Ng Pool Heater - Inground
I've had my Raypak SpaPak (smaller model) for about 2 years. It seems like it doesn't seem to heat the water as hot as it used to - I need to turn the dial to a higher setting to bring the pool up to...
If you do not keep close watch on your water chemistry, depending on your location , you could have a large calcium build-up or salt build up on your electric heating element. Also, these models are meant for spas, and depending on the weather in your location, the heater might have trouble keeping up.
Mar 23, 2011 | Raypak SpaPak Spa & Hot Tub Electric ...
Just drained and refilled, plugged back in and hot tub is not heating. Three lights flashing at temp controls. Is there a reset
Most hot tubs have a freeze protection that will lock you out and run the pumps full blast with no heater if the temerature is under 50 degrees F.The circulating pumps create heat until the water temp is above 50 degrees, and then the heater will come on after that.
Hot tubs do this to protect themselves and it is normal operation.
Nov 22, 2010 | Qca Spas Pool & Spa
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
HL displayed on digital control panel Aruba 1060
Jamie ...
Please do not sit in a tub that is, or claims to be, above 100 degrees F - unless there is a trained, licensed doctor or therapist watching you. 108 is deadly - don't find out by accident.
I think there is something seriously wrong with your tub - you need a pro to look at it. Your tub should not heat above 100 and it should only heat if the pump is running. If it is heating with the pump not running, it will quickly burn out and possibly cause other, expensive troubles.
Thanks for your interest in FixYa.com
Jun 07, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Loss of pressure on Kenmore 16322
I can tell you EXACTLY what is wrong. Remove the tank and open all valves to the grill. Reconnect the tank and turn it on just slightly. Relight the grill.
Ther is a safety device in the tank that needs to be reset. The only way to do it is removing the tank.
Dec 17, 2008 | Kenmore 16322
Pool & Spa Logo
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
