Question about Samsung CLX 3160fn All-In-One Printer
Waste tank always needs to be emptied
The waste tank fills up way too frequently. Could the machine be running too hot to create this problem
  • 1,602 Answers
USING A CHEAPER BY PRODUCT OTHER THAN THE ORIGNAL MANUFATURE MAY CAUSE MORE USAGE COMPAIRED TO THE MANUFACTURE CHEMICAL, BECUASE THE CHEAPER PRODUCTED IS WATED DOWNED OR DILUTED MORE THE CHEMICAL ARE THINED OUT MORE AND REQUIRING MORE FLUID TO GET THE SAME AMOUNT COPIERS PER SHEET OF PAPER
ROD
Posted on Feb 17, 2009
Leaking water
This is really a home style VPR brewer (but looks nicer)
if you listen to their video (link below) they mention it has a pre-heated tank of water already in the brewer. This means the brewer needs to be pre-filled with a full pot of water and pre-heated prior to using the brewer. Unplugging this unit won't be a problem UNLESS it was emptied of tank water and not refilled when powered up.
* The unit will try and heat up the tank of water but if empty then just air which overheats the unit then blows the thermal fuse. Call for service.
* The warmer is still working but it's not hot enough to brew frequently as the warmer may take up to an hour to get the tank hot enough to brew or it may not get hot at all if it's own thermal fuse blew too.
* Water leaking while the brewer just sits there? Leak in the tank. Call for service.
* water leaks only while pouring? Then your pouring to fast. Wait for the water to drop before pouring in more. If it still leaks even while pouring slowly then there is a leak in the fill tray. Call for service.
* Final; call for service to be safe.
Aloha, ukboy57
https://www.amazon.com/BUNN-Velocity-10-Cup-Coffee-Brewer/dp/B00EAQJCWW/ref=sr_1_1?ie=UTF8&qid=1516431654&sr=8-1&keywords=bunn+nhs+velocity
Jan 12, 2014 | Bunn GRX-B
Saeco Odea Go descaling
fill the tank with detergent and let the hot water run for about 15 seconds. Then turn off the machine for about 15 minutes. Then turn the machine back and let the hot water. Then rinse the water tank and fill it with clean water. Run hot water again to empty the tank. Fill clean water again and then you can put down coffee :)
Dec 02, 2013 | Saeco Odea Go
AEG 73630: wont take water in, cant pump water out, when choosing a program the timer seems to have changed minutes with seconds, and when choosing af program, the only thing happening is, af few spins...
The machine knows what the water level should be at every step of the program, so if its full when it should be empty, is not filling when it should be or is taking too long to fill or empty the program will abort and count down in seconds as you describe.
First - check the drain filter for blockage!! if clear, can you hear the drain pump running on 'drain' program? a chug chug chug noise. If not pump may be jammed or seized - or the drain tube maybe be blocked at the waste connection on the sink, etc. Or maybe the water supply pipes have blocked or got turned off? Possibly the waste pipe may not have been installed correctly and the machine is syphoning empty? ie the end of the waste pipe is lower than the water level in the machine - so it syphons empty like draining petrol from a petrol tank! That would empty the machine when it should be full.
Check all the basics of filling, draining and filter before suspecting anything else.
Feb 01, 2018 | AEG Washing Machines
Can I fix waste toner fill box is full by pulling it out and emptying then putting back in. Workio 2010
The waste toner bottle can be emptied but you must clean it out with COLD water after you have emptied it...NOT HOT.
The machine "looks thro" the neck of the bottle to tell if its empty or full so if you empty the bottle and put it back on "dirty" then the copier might still think its full!!
Oct 25, 2010 | Office Equipment & Supplies
Need descaling instructions for EAM 4500 auto espresso machine
use 1/4 cup of vinegar and fill pot with cold water, run through machine
Aug 01, 2009 | Coffee Makers & Espresso Machines
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Water not running through the machine!
sounds like air got in the water lines. Try turning off the machine and making sure the tank is seated good. at menu try an get hot water to get the pump flowing again. you may hear a loud "eh-eh-eh" buzz which means air is in the pump. It will quiet down as the air is forced out. try it several times. Hopefully you get it working. Just remember not to run the tank completely dry.
Apr 03, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Delonghi EAM 6600
You need to descale the machine with descaling solution.
look at following link for instructions
DELONGHI
May 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Samsung CLX 3160fn All-In-One Printer Logo
80 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
