Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer won't stop filling water and e30
Will not stop filling with water
  • 1 more comment
  • Anonymous Mar 23, 2009
    after machine is shut down water keeps seeping into the tub.. had to shut off supply valve to stop the tub from filling
  • renowoman Mar 25, 2009
  • steven924 Apr 04, 2009
    has 3 beeps and it will say ERR and LOC
After a long day of trying to find out why my washer would not stop filling with water I decided to remove the inlet valve of the washer.I found a video on youtube that shows how to do this. All advice I found said that the valve would have to be replaced to fix the problem however I knew that the hot water did not do this only the cold. I removed the valve component and blew it all out with a air compresser to remove any debri that may have gotten into it, and it worked. so before you replace the valve component.try cleaning it out first it may save you 80.00.
Posted on Jan 06, 2013
  • 234 Answers
The problem is most likely the water level switch. Check out partselect.com. They have pictures of the part and a lot of useful information.
If you need more help, post a comment.
Thanks,
Tim
Posted on Jun 16, 2009
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Why does my my frigidaire front loader washer reads diagnostic code e30
Dec 19, 2012 | Hotpoint Ultima WF860 Front Load Washer
Just moved front load beaumark washer into a new house, and it won't fill with water. the display lights up and you can here washer trying to fill (humming noice). All display lights come on and it...
It sounds like your water inlet valve is either not getting a signal to let water in from your control board or the water inlet valve is defective. Since you are hearing a humming noise, I would say that the water inlet valve is defective or has been damaged in transit.
Jun 18, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire washer starts to fill then stops
Check the water level fill sensor. Some used to be pneumatic tubes connected to a sensor. Your washer may have a different type of sensor. It seems like it fills ant gets to a point where it expects the fill sensor to trip but instead just stops. Also re check ALL connections to main drive motor.
Also verify your mains power can handle the draw of the rated wattage. When it goes to engage the main drive motor it may not have enough current from the mains and simply stops.
Also check that the connection to the tumbler drum is not frozen.
May 02, 2008 | Frigidaire FWTBB30DS Front Load Washer
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
834 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
