Question about Epson Stylus CX7800 All-In-One InkJet Printer
My ink cartridges are full but the CX7800 says thay are empty.
I'm not sure what is wrong with the CX7800. It was working fine one night and the next it was caput. I changed all 4 cartridges and still did not fix the problem.
Also I cannot scan as well. The memory card slots work, thank god.
Scott
I tried everything in the manual but still get no print.
What seems to be left is emptying the ink pad. How do I do this?
  • Epson Master
  • 419 Answers
To check if the waste pad is the culprit you would normally get an error message from the status monitor software or on the printer itself telling you that a service was required or parts have reached the end of their service life.
If that's true you can further confirm it by resetting the waste ink counter using a reset utility.
If you're in North America and have the serial number (usually printed on a label on the back) you can go to this site:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
... and fill out the form (making sure you read the warnings and small print) and request the utility for your model.
If you're OUTSIDE of North America then the SSC utility will also work (google: "ssc epson reset") using the protection counter functions.
At this point, because I don't know that particular model personally I couldn't say with any certainty that the problem is the waste ink pads but it can't hurt to try.
Hope this helps.
Posted on Feb 17, 2009
No Cartridges. Open Scanner cover, then reinstall ink cartridge. All Cartridges are full
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty.
To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds.
If the display show: "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace.
Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
Changing the ink cartridges?
I have an epson (2 of them). I have to raise the lid and then hold in on the color button for about 6 seconds. Yours should work similar to mine.
Jul 23, 2010 | Epson Stylus CX7800 All-In-One InkJet...
Lcd screen says no ink but they are full/new
You might have to pull out your cartridge/s and try dabbing the spot where the ink comes out (on the printer - not on the cartridge) lightly - with a Q-tip dipped in isopropyl alcohol.
How long ago was it since you last used your printer? These types of printers don't like to sit for more than a week or two without you printing at least one page on them.
Sep 24, 2009 | Epson Stylus CX7800 All-In-One InkJet...
HP 6310 printer ink Level doesen't indicate any ink in printer
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Mar 07, 2009 | HP Officejet 6310 All-In-One InkJet...
Blinking "E" and "5"
Hi barneyfan -
You're absolutely right - E5 means that the ink is empty (or that the ink can't be loaded for some other reason, such as an incompatible cartridge or improper installation)
For your reference, here is the complete list of error codes for the MP150 with brief descriptions:
E2 No paper (ASF)
E3 Paper jam
E4 No ink
E5 The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera-Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Not recognizing ink
Hi there
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Aug 23, 2008 | Epson CX7800 Stylus Color All-In-One...
Epson Stylus CX7800 doesn't recognize new cartridges
I'm not familiar with your model but Epson has used a very durable ceramic printhead that had a fatal flaw; it wants to be used often, otherwise it clogs beyond restoration.
I have had to junk a number of Epsons (and some rebranded ones too) because of clogged printheads.
They work fine for a long time IF used daily.
The record was one branded Texas Instruments which died after not being used for 2 WEEKS.
I customarily recommended them for hard use but not for home users.
Apr 26, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Can't print when there's only black ink
Mostly it connot print w/out color ink if when printer message empty / sometimes the printer no message while ink was empty still black can print. it depends to the chip .
Jan 11, 2008 | Xerox DocuPrint M750 InkJet Printer
Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Oct 05, 2006 | Brother MFC-5440CN All-In-One InkJet...
Epson Stylus CX7800 All-In-One InkJet Printer Logo
432 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
