Question about Technics SC-DV290 System
Dvd wont play ...each time you insert a DVD it shows DVD HO2...
Technics DV 290 wont play DvD or Cd...Each time you try play the Signal DVD HO2 appears ....
  • 4 Answers
I had the same Problem, player was only 13months old when the error HO2 appeared (typical huh?) anyway 2 years of this thing getting shifted from cupboard,wardrobe,attic, (did'n't want to throw it out cause it cost me £700), finally it came to fix it or bin it time. scoured the net to no avail, lost the rag and half dismantled it..then during all of this ( oops I'm going on a bit LOL)
you can hear a sound as though the disc is trying to be read, after 100's of attempts to get it to work, I finally noticed the disc had not changed position. (disc was not spinning) pointed to the Motor??
what I did to fix this was unplug from main's, remove top cover until you can see the top of the dvd disc, got hold of a pencil with a rubber on one end, plug back in, switch power on, and gently pushed top of disc ( clockwise ) and it kick started it off
that was over 3 years ago and the player is still going strong
I know its a bit rough, but nothing ventured nothing gained ;)
Posted on Feb 17, 2009
The plaver will not play says HO2
1) Dirty or poor pick-up.
2) Sled motor sticking (bad sled motor or contaminated lubricant on the sled rails).
3) Faulty spindle motor. (especially if spindle motor is spinning with top off and no disc inserted).
DVD-RV31 also tends to suffer from dry joints to the surface mount IC's and that could cause all sorts of erratic operation.
Feb 03, 2010 | Panasonic DVD-RV31 DVD Player
Cd tray opening and closing all the time
Dear friend, my sony dvd drive tray opens and closes itself, it is mostly a problem related to hardware. in my case I removed the IDE Data cable connected to the dvd drive and reconnected it again. now my dvd drive works well, I think the problem was the IDE data cable, may be a loose contact.due to this loose cantact,a jung signal goes to the dvd drive, which opens and closes the tray frequently without our knowledge.
Jun 03, 2009 | Technics SL-PD687 5-Disc CD Changer
No play
you most definately have a faulty spindle motor. this is very common on technics and panasonic dvd players. i've come across this fault on numerous occasions and after replacing the motor, all worked as it should. hope this helps?
Jan 25, 2009 | Technics SC-DV290 System
Technics sl-dv 290
I think your dvd is set to a different region. This might help:
1. Insert disk
2.Wait for 'no play'message
3.Immediately press stop
4.It wi go to chapter review automatically in about 5seconds time u should be able to press play and start the movie
Hope this helps
Miss didi
Nov 01, 2008 | Technics SC-DV290 System
Technics sc-dv290
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Oct 26, 2008 | Technics SC-DV290 System
Technics DV290 system shows "change 1" error
i have a technics sh-dv290 and i need to know how to link the dvd to my tv???
jack
Feb 26, 2008 | Technics SC-DV290 System
Technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Sep 20, 2007 | Technics SC-DV290 System
Won't play cds or dvds
you need a new motor in yr dvd player i had same problem had new motor works now
Aug 04, 2007 | Technics SC-DV290 System
Dvd ho2
The problem centers round a spindle issue that is a known design flaw. Basically what happens is that the spindle gets warm, expands, and is then pushing on the top of the player . The following link shows a cheap fix..Hope it works for yours.
http://www.imjosh.com/?p=247
Jun 13, 2007 | Technics SCEH790 CD Shelf System
Technics SC-DV290 System Logo
393 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
