Question about Logitech Cordless TrackMan Wheel Mouse
Does not move cursor, some times it moves but no control
I left it on as usual over night. It will not move at all on any of my other PC's. One time it did move but without control.
  • el_kahara Feb 17, 2009
    I did tak it apart and cleaned. I saw the pointer move erraticly at on time, now it does not move. I used in different PC's, same issue. No light as far as I can see. however under the track ball is a window that after inspecting I did see a round window. Does a light come out of that?
    I took it apart only to inspect the components. No visual damage The mouse was dropped at one time but still worked.
  • 2,794 Answers
You don't have to take it apart to clean it. The ball is designed to be removed from the unit by releasing it from the bottom of the control. Then you just simply clean off the red area with a cloth. Do not use alchohol on the surface. It could damage the unit.
Posted on Feb 17, 2009
  • Tim Babcock
    Tim Babcock Feb 17, 2009
    Is the red light coming on?
  • 1,602 Answers
REMOVE THE SCREWS FROM THE BUTTOM OF MOUSE REMOVE ALL LINT AND STUFF FROM AROUIND THE MOUSE WHEELS, CHECK THE CURCUITS, IF REQUIRES A BATTARY THAN MOVE THE LEADS TOWARDS THE BATTERY 1/8 INCH FOR EACH BATTERY TO MAKE TIGHT FIT AND LESS MOVEMENT TO THE POWER SOURCE.
CLEAN THE LIGHTED LIGHT WITH Q-TIP AND SOME ACOLAHOL.
RE-ASSEMIBLE MOUSE, RESET THE MOUSE DRIVERS OR UPDATE
REBOOT SYSTEM
CANDYMANGANDY
Frozen cursor
The only reason your cursor would "freeze" is your CPU is running at 100%. Press "control-alt-delete" keys at the same time and find the process that overloading the CPU and close it.
If you cursor never moves, your glidepad is broken. Do you have a "stick" to move your cursor? Many Thinkpads do. Usually have a red cap on it and is located near the b g h keys. If the stick doesn't work either, it's the overloaded CPU problem.
Oct 24, 2013 | IBM ThinkPad T42 Notebook
Need to swipe touchpad numerous times for it to move
I would suggest you to check the touchpad app in control panel. I guess your have synaptic drivers installed see if you can adjust few settings to suit your touch sensitivity.
Aug 24, 2012 | ASUS Computers & Internet
Set date and time
Press the MENU button. Use cursor-left/right to select Setup, then use cursor-up/down to select "Date & Time". Use cursor-left/right to move between the fields, cursor-up/down to change them. Press the OK button when done.
Apr 08, 2012 | Kodak EasyShare CD14 Digital Camera
My cursor moves around but to get any where or scroll I have to left click every time
Enter your control panel from the START menu select CONTROL PANEL open it scroll down to mouse and adjust settings there.
Apr 07, 2012 | HP Computers & Internet
Can't change date and time changed on kodak easy
Press the MENU button. Use cursor-left/right to select the Setup tab. Use cursor-up/down to select "Date & Time". Use cursor-left/right to move between fields, cursor-up/down to change them. Press the OK button when done.
Sep 06, 2011 | Kodak Cameras
G netbook cursor moves way too fast but i find no way to slow it down. apparently the solution is not in the help file.
The touchpad is very small on this netbook, so the ratio between the finger movement and cursor movement has to be high in order to be able to move the cursor from one side of the screen to the opposite.
The cursor cannot be too slow, because you would have to glide the finger several times on the touchpad to move it across the whole screen.
However, the speed of the cursor can be adjusted in the mouse properties in Control Panel (Start->Settings->Control Panel->Mouse) in the Pointer Options tab. Experiment with different settings to find one that suits you.
With such small touchpad I would suggest forming a habit of rocking the finger on the touchpad to achieve better precision and control, instead of sliding it. Put a finger on the touchpad center and tilt it left/right, up/down - You'll see that the cursor can be controlled quite well this way. And if you need a larger movement, then it's enough to move the finger the normal way.
Good luck and please come back with a rating/testimonial if helped.
Aug 01, 2010 | Sylvania G-Netbook
My letters are way to small i cabbot read them
Go to: start, control panel, display, settings, set Color quality to 32 bit and move the screen resolution cursor toward less or more, example: 1152 by 864 or 1024 by 768 click apply then ok. Every time you move the cursor you need to click, on apply to see the result.
Best of Luck
Sabre
Feb 18, 2010 | Gateway GT5468 Desktop PC
Automatically cursor jumps . When we type in the cursor automatically moves fromm one place to another
I presume you have a touchpad under your keyboard.
Usually the hand position when you type is such, that it's very easy to involuntarily lighlty touch the touchpad with the base of your thumb, usually the right one, when you move the hand over the touchpad, mostly in the up-left direction.
This causes the cursor to move to some other place, usually up and to the left, resulting in the next characters you type being put in that place :)
Try to keep your hands a little bit more above the touchpad when you type. Also, many touchpad drivers have settings for ignoring light touches/drags, try looking into these settings in your pointing device properties.
As an aid, I would recommend a soft gel wrist support, which automatically elevates your palms above the keyboard.
Nov 13, 2009 | IBM Lenovo ThinkPad T400 7417 Notebook
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Logitech Cordless TrackMan Wheel Mouse Logo
97 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
