Question about Philips HD2533 2-Slice Toaster
"Outside" heating elements don't heat up. Can I find replacements
Toaster is Model HD2533 (Phillips). Are heating elements available anywhere and can they be replaced easily? Inside elements on both sides of the 2-slice toaster work fine...and no, the bagel button isn't depressed!
  • jerndori Feb 19, 2009
    Thanks, cactus bob. Your solution certainly makes sense and I will probably try to do that repair but doubt, with this old man's arthritic fingers, that I'll be able to accomplish the task. The old Phillips has been a good toaster for almost 9 years but it may be time to try and find another decent one. Wish me luck!
    President:
  • 267 Answers
Its not the elements . its the control board . and you cannot buy a control board , but it can be fixed there is a small relay on the board that needs to resoldered to the printed curcit board . its a pain the the rear-end to get to it , fix it and get back in there and all back together but it can be done ( about 3 hours total ) , if your like me and never say never ......... good luck
Posted on Feb 19, 2009
    Problem Solver:
  • 4 Answers
I just had this problem happen to me. I shall try the 'Resoldering of the Relay to the Control Board'. fix. I'll let ya all know what happens.
- Pj
Posted on Sep 30, 2011
  • PjR7 Sep 30, 2011
    - Pj
The coils (heating) do not appear to be working Tost comes out warm but not brown!!!
Inside your toaster there are four heating element plates two in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Mar 27, 2010 | Dualit 20247 2-Slice Toaster
Not toasting evenly
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end.
Remember that the four in center are the same called "CENTER" and the other two on ends are the same called "END"
Good Luck
Mar 26, 2010 | Dualit 31210 3-Slice Toaster
One side of my dualit 4 slot toaster is not working can you help?
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Remember that the six in center are the same called "CENTER" and the other two on ends are the same called "END"
Good Luck
Jan 19, 2010 | Dualit CBF4M Stainless Steel Buffet...
The center panel of my 2 slice Dualit toaster is not heating. Can I replace it?
Good Luck
Jan 06, 2010 | Dualit Vario 2 Slices Toaster
One of the elements does not work
Good Luck
Jan 02, 2010 | Dualit 20247 2-Slice Toaster
I think the elements are no longer working. can these be replaced or fixed?
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red. They can not be fixed.
Good Luck
Nov 29, 2009 | Dualit Vario 3 Slices Toaster
I need the elements replacing
Good Luck
Nov 21, 2009 | Dualit Vario 3 Slices Toaster
All slots not heating
Good Luck
Nov 16, 2009 | Dualit Vario 4 Slices Toaster
Our 4-slice toaster (model 4cbc) is only toasting part of one side of the toast, as if a heating element has burned out.
Good Luck
Aug 05, 2009 | Dualit Kitchen Appliances - Others
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
Philips HD2533 2-Slice Toaster Logo
252 people viewed this question
Top Philips Kitchen Appliances - Others Experts
Dennis Maeder
Thomas Perkins
Thomas Perkins
Robert Kilpin
Robert Kilpin
Are you a Philips Kitchen Appliances - Other Expert? Answer questions, earn points and help others
