Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Sharp LCD tv "Audio window" keeps popping up on the corner
Hey all,
Just bought a new 32 inch Sharp LCD tv... Apparently this is a common problem: intermittently a window pops up on the (my) right corner of the screen giving me a status of the auido it switches from "Stereo" to "mono". There is no way to turn this off through the menu functions. Which blows me away. My tv is plugged into a comcast digital cable box.... which "Should" alleviate the problem but doesn't.
Im planning on getting a hi-def box from Comcast. Would this fix it? I've been getting the feeling that my current cable box is a piece of junk anyway.... Any help would be great. Thanks
  • jaeding Apr 01, 2009
    I just bought the 37 inch Sharp and it is doing the exact same thing (intermittently a window pops up on the (my) right corner of the screen giving me a status of the auido it switches from "Stereo" to "mono".) IT is driving me up the wall and I am ready to take the TV back!
    President:
  • 1,077 Answers
Replacing the cable box may fix the problem. But, you're the 4th person to have this same problem with this SHARP TV MONO only audio.
Try system reset button on the back of the TV or the box.
Posted on Feb 17, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
My sharp aquos lcd tv 32 inch usually gets hard time in turning on coz once a brownout occurs and when i turn it on only the green light appears without pictures so i have to unplug it on and off as...
Sounds like you have bad capacitors somewhere in the TV. If none of them are bad, you could also have loose grounding screws on the inverter shield. It is common for this TV and simply retightning them will keep the backlight on again.
Mar 23, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
32 inch LCD sharp tv switches audio from mono to sterio every 4 to 5 min
When you are connecting this television to a signal source with a coax cable this happens. The solution is to connect with an RCA/composite cable instead and utilize the television's inputs instead of using input tv.
Jan 16, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Audio keeps switching from mono to stereo
on every channel ? then av board is failing
on a single channel then it is their signal not you set
Nov 24, 2009 | Sharp LC-32SB21U 32 in. LCD TV
Sharp aquos 32 inch lcd. suddenly only audio,, no pic (blue and now black screen)? is this normal failure - repair said new panel required but cost same as a new lcd - BER - 3 months out of warrenty. HELP...
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
It sure sounds like the tech is too lazy to do some troubleshooting. These two parts are the most common things that go bad. It is easy to collect the money by giving high estimate for repair. It give us the repair guys the bad name.
Please post back what you find.
Nov 16, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
32 inch Sharp Aquos Screen is cracked. Can it be
Yes, however, the Display is as much as a new set.
Oct 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Air analog 3 message keeps popping up what does that mean?
I bought the 32 inch LCD tv. I contacted Sharp. Here is there response.
Thank you for contacting Sharp Electronics Corporation.
The display will populate on screen any time there is a change to the incoming signal (mono to stereo audio, weak/fluctuating signal strength). Unfortunately there is no way to deactivate the on screen display. If you are able, try using an alternate connection (composite video and analog audio; yellow, red and white cables) from your source device (cable/sat box, if using) to the unit. This will prevent this issue from occurring by providing a more consistent signal. Let me know if you have any other questions!
Jan 02, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
Wharfedale TV power problems
got a 32 inch wharfedale tv from argos also and it seems to boot up and then shut down and just loops, if i keep unplugging it i can sometimes get it on but with a high pitch wailing, only 15 months old, gutted!
Jun 16, 2008 | Televison & Video
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
608 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
