Question about Philips Magnavox 42MF521D/37 Television
Left speaker port shorted out
This is a tricky problem, so I am sorry if I lose you.
I have a 37" Magnavox with an external speaker frame that has a left and right speaker inside that attaches to the bottom of the tv itself. Both speakers work, there are 4 cords that attach to the TV, a red and black for the left, and a red and black for the right. I know both speakers inside the frame work because if i plug them both into the right port on the TV, they both work. My problem is, the left port on the TV doesn't work. So if I have the left speaker plugged into the left port, I get no sound. If i plug both into the right port, they both work, but I am only hearing what is meant to come out of the right speaker.
Here is an example of what I am not getting... If you listen to headphones and pay attention, you will hear some beats in the right speaker, and some beats in the left speaker. My left side speaker port doesn't work, therefore I am only hearing what is meant for the right speaker and not the left, so I am not hearing every sound and it is like listening to headphones with only the right one in.
I play a lot of games and you can tell enemy direction from sounds, explosions on your left or right, gunfire on your left or right, I only hear to the right. I would really like to know what the part is called so I can have a repairman come out and replace it.
The TV is no longer under warranty, only had a year warranty and I have had it for about 15 months now.
Thanks.
  • RM Feb 17, 2009
    The model # for my TV is 37MF321D/37
I found that the part is called a speaker input and I was able to find one and am having it replaced. Thanks.
Posted on Feb 18, 2009
Magnavox troubleshooting
This is a plasma TV, lose color usually means buy new one.
Jun 09, 2014 | Magnavox Televison & Video
Would like to add on another speaker
You can add using the audio port( green color jack). Just get an audio cord and connect to an external speaker.
Nov 23, 2013 | Magnavox Televison & Video
Philips sound problem
NO sound? If so check to see if set works with a DVD etc connected to a rear input and has sound or not.
Also if no sound check in menu to see speakers not set to off or to external speaker connection if set has that.
Dec 18, 2012 | Philips Magnavox 42MF521D/37 Television
How to hook up external speakers
There is no direct port to hook up external speakers. you have to use an amplifer to get connected in between TV and amp, using an AV cable.
Sep 29, 2012 | Magnavox 47MF439B 47 LCD TV
42MF437B/37 magnavox tv no power making buzzing sound
It sounds that there is some shorted component/s one either main power regulator board, or at the main digital board. Your TV need a through checkup.
Sep 11, 2012 | Philips Magnavox 42MF521D/37 Television
Magnavox LCD tv external speaker
Hello
The jack you describes here "Digital Ouput Device To" means, you can connect these jacks to the output of a digital device, such as DVD or so. It is meant for to get signal into the TV, not ot out.
HDMI [High Definition Multimedia Interface] is a type of connection, which the TV an be connected to any HDMI device from outside. Both the above said are, signal in to TV connections. Not out.
If you want to connect this TV to any amp or any other external audio devices; look for any audio out option is there.
Feb 05, 2012 | Televison & Video
Magnavox model S1MP6100D/37 I have a large screen
there are 2 stk392-120 chips mounted to a large heat sink. both are bad, also 6.8 ohm 1/4 watt resistors are bad . need ohm meter top check these.
Nov 16, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Magnavox 42mf521d/37 sound but no picture
The solution is the same I used for srjohnnichol, June 4, 2009. I promise you, this will correct your problem. Stop waiting an getter done!
Jul 27, 2009 | Philips Magnavox 42MF521D/37 Television
How do you connect external speakers. Which
use hte head phone output as the speakers have that jack plug
Jun 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Short in Speaker Jack of my laptop
here is how you should disassemble your laptop
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00502970/c00502970.pdf
i dont see how a usb port can actually be related to your sound but maybe the best solution right now is to simply replace your usb port as it might have been damaged by your external usb keyboard
Apr 05, 2008 | HP Compaq nc6120 Notebook
Philips Magnavox 42MF521D/37 Television Logo
228 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
