Question about iLO 2600 Television
NO Picture! NO POWER! NO NOTHING! ILO 27' LCD
My 27 inch just recently stopped working. I noticed a problem with it about 3 months ago when i would try to turn it on and nothing would happen. I would then unplug it and then plug it back in and then it would come on. But for the past week that doesn't even work and it want power on or do anything at all now. Somebody let contact me if you know how to resovle the problem.
  • 2,326 Answers
The way to resolve the problem would be by replacing or repairing the power supply. If the TV does not power ON, needs to be unplug to make it work; those are symptoms of a dying or defective power supply.
I repair these power supplies, if you need further assistance write to jah2mil@hotmail.com
Posted on Feb 21, 2009
Ilo tv quit - will not turn on
The Problem is with the Capasiters in the power supply bord a total of 9 caps have to be replaced the power supply bord is the one on the right side of the tv in the back where the power cable enters the caps values are 35 volt 1000uf x2 35 volt 470uf x3 16 volt 1000uf x3 and 16 volt 470uf x1 after replaceing thses caps the tv will work like new... i hope this helps.
Apr 09, 2009 | Televison & Video
Horizontal Line through middle of TV screen
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Feb 04, 2009 | iLO V27DMBX Television
Lcd ilo 27 inch
THE TV 2 HAD TO PUT ON CHANNEL 60/ AIR, SIMPLE FIX THANKS
Dec 10, 2008 | iLO 2600 Television
Insignia 27 inch lcd tv gets no video or audio
the most common item that fails with all LCDs is the power invertor or power supply, and that sounds like what your set is needing is the capacitors have possibly failed on the Invertor
Jun 28, 2008 | Televison & Video
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
Ilo-27 lcd
I CAN,T GET IT TO CHANGE CHANNELS. I DON,T HAVE THE ORIGINAL REMOTE SO I HAVE TO USE A UNIVERSAL AND IT WON,T PROGRAM.
Jan 13, 2008 | iLO 3200 32 in. LCD Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Infrared light out, power light out
notice if your buttons on the tv work properly. sometimes the curcit board that holds the lights,ir ect, falls off from inside and then they cant be seen or work
Jun 04, 2007 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Nothing!
I do not have a solution but the same thing happened to me today. Just nothing
Jun 01, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
99 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
