Question about E-Machines T2682 (000002965) PC Desktop
Screen Resolution I just purchased a 32" LCD tv that I hooked up to my emachine desktop. I am trying to make it fit to my new screen but I have these black bars on the left and right of the screen. When I try to make it larger it won't go past 1024x600 or whatever it is. Please help!!
  • 1,602 Answers
THE DRIVERS MAY NOT SUPPORT THAT BIG OF MONITOR AND THE VIDEO CARD GRAPHICS MAY NOT BE ABLE TO SUPPORT THE SCREEN, PUT IT ON 720X600 SEE WHAT HAPPENS OR PUT ON LOWEST SETTING ON THE PC GRAFTIC SETTING OR LARGES RESULUTIONS SETTING, THE SOFTWARE MAYNOT SUPPORT THE TV, VESA - VERSA
MANUFACTOR IS NOT COMPATIBLE. AND I MAYBE TOTALLY WRONG
LETS SAY THE VIDEO CARD AND GRAPHICS ARE MADE FROM BOTH MANUFACTURES THAN CALL THE VENTER AND SENT THE CONVERSION SOFTWARE TO DO THAT .
JUST THINK WHEN THEY MAKE A MOVIE IT IS ON A LARGE SREEN AT THE THEATER 6-8 FT
SCREEN AND THAN IT COMES ON TO DVD THEY HAVE TO USE SOME SOFTWARE TO REDUCE THE PITCHURE SO IT CAN FIT ON THE TV SCREEN OR YOU WILL ONLY SEE PART OF THE SCREEN THAT CAN FOCUS ON
CANDYMANGANDY
Posted on Feb 17, 2009
Hdmi input not working
Try right-clicking on your desktop while tv is plugged in and select screen resolution, that should open the properties window that will allow you to activate or change resolutions for the tv or detect it. Make sure that the tv is enabled and if necessary choose to extend your desktop to it.
Jan 16, 2014 | Sylvania LC320SS9 32 in. LCD TV
I am trying to hook up my computer to my lc321ss9 b tv. I hooked it up to the VGA port and it says format not supported?
your screen resolution probably exceeds that of the tv.
try playing with your screen resolution.
May 02, 2011 | Sylvania LC-321SS9 32 in. LCD TV
I purchased a gateway HD2201 monitor all I see is white screen
Maybe your resolution is not set to the right settings for your new screen, set the resolution and refresh rate lower with the old screen attached and try again with the new screen
Jul 18, 2010 | Gateway HD2201 22" LCD Monitor
When I hook my tv up to my desktop computer the screen looks like it is going to work (it says dell then the loading bar fills up) as a monitor until it is time for my log in screen to come up. The screen...
hi,
This is normally due to a frequency or resolution incompatibility. Turn on your desktop computer, then change the screen resolution to 800x600 or 1024x768. Save the settings. Reboot to check that it is indeed saved.
Once you boot up on your TV, it should display fine. Gradually increase the resolution and colors to the max your TV can handle.
Feb 28, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Im having trouble hooking up my desktop computer up to my Akai LCT3285TA tv? what am i doing wrong? I have both VGA hookups connected and screen says not supported?
The screen indicates 'not support' because the resolution you are try to feed the TV exceed the maximum it can display, you need to set your computer video out put resolution the TV native resolution, which you need to find out by download the user manual here: http://www.retrevo.com/support/Akai-LCT3285TA-TVs-manual/id/741bh147/t/2/
Dec 15, 2009 | Akai LCT3285TA 32 in. LCD Television
Dented the screen on my 32" Vizio LCD, now 1/2 picture is gone. Is it cost effective to replace the screen, and if so where do I purchase a replacement?
HELLO
I have posted this answer many times now regarding LCD screens. If the screen gets a high impact then it is gone! To get a new screen fitted will cost more than a new TV.
The only solution is a new set - that is how it is with LCD screens (:-(
Oct 21, 2009 | Vizio L32 32 in. LCD HDTV
I have an eMachines and when i hook up my 42in LG HD LCDTV says
You resolution on the eMachine is higher than what the 42inch LCD can support .. reduce is to size by check the LCD manual and make change in window display settings
Jul 18, 2009 | Computers & Internet
Proscan 32'' VGA port; TV says not supported on VGA input
Sounds like your resolution on your computer is set too high for your tv to accept. Try putting your computer resolution down to 1024x768 or lower and see if that works.
Jul 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Can't get a connect from my emachine to aco l32w761
2 options:
1) Try changing your screen resolution to say 640x480 or 800x600 ..
2) Try it in safe mode also ..
Jan 21, 2009 | Envision L32W761 32 in. LCD TV
Not supported mode error
Hi, boot up to an F8 and select safe mode. While there change your screen settings to 800X600.
The available resolutions in the windows operating system has to be compatble with the TV screen you are hooked up to. try lower settings first.
Thank you and god luck.
Oct 25, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
E-Machines T2682 (000002965) PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
