Question about MyMusix PD-6070 MP3 Player
When I turn on the mp3 player, it says system is protected.
Basically it runs through all its updates and initializing, but right before it goes to the play list, it says System is protected.
  • Anonymous Mar 06, 2009
    I can only charge the device. After that it just keeps displaying the boot sequence and keeps saying ''System is protected' until the batter discharges.
  • anthonych863 Mar 11, 2009
    My player does the same thing.I'm dying without portable tunes.
Try the reset. If that doesn't work download the Palyer Update from http://mymusix.com.
Posted on Apr 01, 2009
My mp3 seems to be stuck on initializing. When I plug it in there is no box that asks what I would like to do with it. I can turn it off and when I turn it back on it still says initializing. It was...
There should be a small hole somewhere on one of the sides of the device, small enough that only something such as a needle or a paper clip can fit into it. use a small item to press the button that resides in this hole. Most modern MP3 players have this small hole and its a basic reset function for the operating system that runs the MP3 player. Also you may want to try updating the firmware on your device here
May 02, 2011 | RCA M4204 MP3 Player
The music has transferred over from my pc to my mp3 player but when I try to play it, I just get a message of Media error DRM not supported. What does this mean? It is a SA1983A/02
DRM is so that an MP3 cannot be copied. It is Digital Rights Management, basically so that you can only use it with systems, like your player, that make sure it isn't stolen. It is used very little these days since Apple took DRM off of iTunes files, but it is quite annoying and is just that, copy protection.
Apr 10, 2010 | Philips GoGear HDD1830 MP3 Player
My Coby mp3 player won't connect to my computer
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and photo folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF ! ! !
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player battery charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the player turned OFF connected to the computer.
IT WILL NOT CHARGE WITH A COMPUTER UNLESS IT IS TURNED OFF WHEN YOU CONNECT IT.
f. Use the Coby Manager to disconnect the player
(Found HERE if you have had to format the player)
CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Go to the DEVICE TAB
2. CLICK on EJECT Button in lower right hand corner.
3. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
4. The second pop-up screen will tell you "The device can now be safely removed from the system."
5. The Coby will now show "Please Wait..."
6. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps
Apr 05, 2010 | Coby MP-610 MP3 Player
My RCA model M4208GR-B mp3/video player is stuck on a screen that reads, "initializing..." I've tried everything I can find on the web about it, without success.
Go to "http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=2559"
To update the firmware of the M42xx mp3 player click hereand download the firmware. start the firmware and when it is runninplug the M42xx in at the same time holding down the PLAY BUTTON(center) until a white screen with a small computerwith a line going to your M42xx is displayed and then release the PLAYbutton. You can then click on start and the firmware update willcomplete,,, DO NOT DISCONNECT DURING THIS UPDATE... it may take 2 timesto complete this but it will work.... YEA!!!! WORKS with 2, 4 or 8 GBModels.....
I Tried the above...initially it didn't work, but then i tried it 2 or 3 times, and tried by connecting it while the "initializing", and then tried it after turning it off and then suddenly it came to life...just try some stuff it just might work...i.e after u download the firmware. Credit goes to the guy posted the original thing.
Jan 16, 2009 | RCA M4208 MP3 Player
Occuring the problem when turning on with the title"bulding eror"
Click here for Firmware Update from samsung.com
Here is the instruction for updating the firmware:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port(Hold down the play button while you connect the device, you should seea message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message"Initializing" on YP-U2J Updater, you can now remove your hand fromplay button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUSTdisconnect the Mp3 player and turn it on. You will see a 20% messagefor about 50 seconds and it will be restarted automatically.
Dec 13, 2008 | Samsung YP-U2X Digital Media Player
My mp3 player says initializing
Same here...I hate Phillips right now
Aug 16, 2008 | RCA M4204 MP3 Player
Mp3
Follow these steps:
CLICK Here to Download : Firmware Update
Here is the instruction:
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Jan 04, 2008 | Samsung YP-U2X Digital Media Player
Why does my mp3 player keeps blinking
try taking out the batterys for 24 hours and trying it after that?? let us know please
Apr 13, 2006 | RCA Lyra RD1072 MP3 Player
MyMusix PD-6070 MP3 Player Logo
268 people viewed this question
Top MyMusix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
