Question about Canon Office Equipment & Supplies
I have a Pixma MP460 printer and when I try to make a copy (not from the computer) I get an error 5100 - can you help me fix this problem? Thank you. Wilma
  • Canon Master
  • 13,433 Answers
Press the on off switch and turn the printer off and then on
if that didn't help
reaset the ink cartridges
if you still get the error the printer may require repair.
Posted on Feb 17, 2009
  • 153 Answers
Did u check if ink there in catridges
  • nicra7 Feb 17, 2009
    try unplugging it and repowering it
    it might be a catridge prowlem
  • Canon Master
  • 19,396 Answers
Try first unplugging the power cable to reset the printer.
  • Ginko
    Ginko Feb 17, 2009
    Error 5100 is wrong cartridge position.
    First follow the indications here: ERROR LCD: Error Code 5100
    either the ink carriage is stuck or you need to clean the encoder strip with isopropyl alcol and cotton.
    The encoder strip is the plastic strip that runs aside the traction belt, The encoder strip is a sensor that tells the printer control board the position of the ink carriage.
  • Ginko
    Ginko Feb 17, 2009
    Brigadier General:
  • Canon Master
  • 3,614 Answers
try unplugging the unit for a while.
resit also the cartridge
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Error 5100 cannon mp460
The root cause of Error 5100 in Canon inkjet printers can be so varied and so the solutions. If you want to read a best and well researched article on this topic, read it here:
Canon Error 5100
Oct 30, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5100 on cannon pixma mp460 Does not load paper
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve this error follow the given steps:-
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed.
I hope this solution helps you
Let me know If you have any more Confusion, questions or issue regarding your problem
Thank you and Keep using FixYa!
Sep 26, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Error 5100
Issue: ERROR: Service error 5100 appears while printing from the computer
1. Allow print head to cool down
2. Disconnect and reconnect the USB cable to ensure a secure connection
3. Press ON/OFF switch to reset the multifunction device
4. Reseat ink cartridge (MP160 / MP180 / MP460)
5. The MP180 may require repair
Try the above..
Oct 18, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Printer is not printing from the computer. copy
Hello Try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All Best: Pineworks
Jan 07, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Error 5100
How do I fix error 5100?
Oct 04, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5100
This might help: http://www.fixyourownprinter.com/forums/laser/25975, they had the same problem
Oct 25, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon mp460
Dear thechad,
go to the canon website (listed below) - under Tech Support - click on Technical FAQ's (this will pop up another small window)
then click on Search by Key Word
next - type in error 5100 and click on the circle next to - Include all words and hit Search
next - click on the link with your answer "how to.... "
this should show the answer
http://www.usa.canon.com/consumer/contro...
Cheerup
Mar 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
old marine
old marine
